2nd 1quart top up in 6 month
12-29-2016, 08:20 PM | #1 |
Rep 267
Guys,
Is two quarts top up in 6 months since oil change excessive for n54is? Car is bone stock and not drive. Excessively hard Any thoughts? |
12-29-2016, 09:52 PM | #4 |
Rep 9,209
12-29-2016, 10:15 PM | #5 |
90
Rep 386
Drives: 08 535xi 11 328xi
typically yes 2 quarts is a bit much in 6 months but you need to factor in miles. if I add any oil, it's at most 1 quart between oil changes and it's closer to when it needs to be changed based on a 10 k mile oil change interval. if you don't see any leaks or smoking out of the exhaust, you may have an issue with your e-dipstick. when I get the add 1 quart warning, I don't top off right away. I wait a few times to make sure it's actually low. 1 quart low will not in any way harm the engine.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
12-30-2016, 02:51 AM | #6 | |
Guest
Rep n/a
Drives:
12-30-2016, 08:16 AM | #8 |
Rep 267
Thanks for the feedback guys,
In the 6month period, the car was driven around 6k miles and excessively hard and never over 100mph - BMW oil - car is at 60k miles |
12-30-2016, 08:34 AM | #9 |
Rep 460
How many miles did you drive? Our 2007 uses a quart every 1600 miles which I think it high but according to BMW acceptable. Our 2008 335i and 2010 535i use hardly any oil between their 5000 miles oil changes.
We also have the BMS catch can's and RB PCV valves. The 2007 which uses oil, that catch can will have a couple ounces in it every thousand miles too while the other two cars just a couple of drops of oil. |
12-30-2016, 11:40 AM | #10 |
537
Rep 2,825
its not so much how hard you drive the car currently, but how the first owner treated it particularly for the first 3000 miles which is an important break-in process. if you rev it hard a bunch of times during this process, things like your piston rings wont properly seat and you will burn oil.
another thing is also which oil you use. if you use 0w-30/40, expect to be burning alot more oil. if you switch to a good quality 5w-40 oil like liquid moly or especially motul, expect to see much less oil top ups in the future. |
