V2 installation - software problems.
04-13-2008, 03:17 PM | #1 |
Rep 18
Hi everyone
Guess i really am an unlucky procede user. Here's the first post describing my problems: http://www.e90post.com/forums/showthread.php?t=129018 And here is what we did on the installation of recently received v2 box (car #1, 07 335i, MT): 1. Did all the wiring. The car started with bypasses without errors. 2. Connected procede. No errors. 3. Tried it on the road (after driving about 50 miles): got limp mode on 4000 rpm at 3rd gear. The day after got into limp mode at 6500 rpm on the 2nd. 4. Decided to upgrade firmware / install latest maps. 5. During upgrade to pro01v03beta1-1 (downloaded from your post with latest firmware), the software indicated erasing of the old firmware and suddenly showed an error uploading the new one. the message said “firmware upgrade failed, please upgrade again”. After this, we could not connect to the procede unit, it would show its offline all the time. 6. The car is now on bypasses. QUESTION 1: Is there a way to fix the unit (get it back to online mode) and upload correct version of firmware? Almost the same thing has happened during upgrade to v2 from v147 (my car - 06 335i, MT). 1. Did the wiring. No errors. 2. During firmware upgrade (same file as above), the software erased the old firmware, but again showed an error during v2 install. The box went offline and we could not get it back online. When trying to reconnect, the software said something like “ECU is in a boot mode”, showing “offline” status all the time. 3. That car is now on bypasses too. QUESTION 2: Can that unit be fixed without sending it to the U.S.? QUESTION 3: Is driving on bypasses absolutely safe for the car? |
04-13-2008, 03:21 PM | #2 | |
442
Rep 18,331
04-13-2008, 03:24 PM | #3 |
IT geek
Rep 187
My only suggestion would be to find anyone else in Moscow with a Procede and sport him/her a few rubles to borrow there unit for a test drive. If all goes well, you either have a defective Procede or you had a latent computer problem that is holding you back or did f-up your Procede.
04-13-2008, 03:32 PM | #4 | |
Rep 3,928
Launch the software and load up the firmware (not the map)..then try and connect again....give it time...it should load.
'07 E90 Jet Black/Black Leather | ZSP| ZPP | ZCW | AT | Paddles | Hartge Lip (Rep) | Blacklines | Ultimate Racing CAI | PROcede v2.0.2-26 |
04-13-2008, 03:38 PM | #5 | |
Rep 18
04-13-2008, 03:39 PM | #6 | |
Rep 18
04-13-2008, 04:01 PM | #7 |
Rep 507
Have you tryed this solution for boot mode?
[QUOTE=Dustin@Vishnu;2134253]I have had a few people whose PROcede has gone into boot mode after trying to update their firmware. This can happen for a number of reasons, like a laptop dying in the middle of the firmware update. Getting everything back to normal is quite simple. When you try to connect to the procede after a failed firmware update, the software will say "Procede in boot mode, please update firmware." 1. Go into comms> Firmware update, and update the firmware the same as you would otherwise. 2. At the end of the firmware update, the Procede will be stuck in the reset, and will not go online. So we need to manually reset the procede. To do this, shut down the Procede software, as well as the power to the procede (turn the car off). Leave the power off for at least 1 minute. 3. Turn the car back to the on postion, and restart the software.
M3 E92 ESS VT-625
04-13-2008, 04:07 PM | #8 | |
Rep 18
[QUOTE=per;2481238]Have you tryed this solution for boot mode?
Both times when the update failed there were no problems with the laptop. |
04-13-2008, 05:33 PM | #9 | |
Rep 3,928
[QUOTE=Injecto;2481257]
04-13-2008, 05:50 PM | #10 |
36
Rep 1,658
Druzeskii sovet. Vibrosi eto Induskoe dermo v musorku ili poprobuii prodat'. U menya stol'ko problem s nim bilo za celii god nesaschetat'! Poprobuii JBX vmesto. Bol'she duri i ne odnoi' problemi.
04-13-2008, 06:20 PM | #11 |
BMWCCA member #2429
18
Rep 136
I feel for you, but why do people complain abour Dinan when this kind of crap happens. The stress alone is worth buying the Dinan over procede.
Like Simon says,I know I'll hear about this! |
04-13-2008, 07:49 PM | #12 |
Rep 2,225
Last ditch effort would be to remove the procede and send it back to vishnu for evaluation. On very rare occassions you will get a bad v2 unit.
Only do this if all else fails.
07 335i sedan | Steptronic | Black saphire | Terra | ZPP | ZSP | Cold Weather | CA | PDC | Nav | OEM Alarm
04-14-2008, 02:51 AM | #15 |
Rep 1,432
Mine was such where the procede unit was faulty. I would not rule out that possibility. No one thought there was such a thing. And i was the first.
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| |
04-14-2008, 07:56 AM | #16 |
Rep 3,928
PM Dustin@Vishnu, he typically responds within 24hrs., if not sooner.
04-14-2008, 08:02 AM | #17 | |
Rep 3,928
Car off = Keyfob out of ingition Car on = Just the power, not the motor. Follow the instructions exactly..give it some time. Goodluck
04-14-2008, 11:20 AM | #18 | |
Rep 2,225
Again...chances are low for this, but it happens! Mine runs great now by the way....I'm very happy with everything.
04-14-2008, 03:23 PM | #19 |
Rep 18
So far I still have no idea what to do next. Driving with bypasses is not much of a pleasure.
Help is greatly appreciated. Still waiting for a response from Dustin/Shiv |
04-14-2008, 03:34 PM | #20 | |
36
Rep 1,658
Gl |
04-14-2008, 03:37 PM | #21 | |
99
Rep 1,712
http://www.vishnutuning.com/tech_callback.htm |
04-14-2008, 03:55 PM | #22 |
Vishnu Powered
68
Rep 2,205
I have had this problem where the firmware fails while uploading...
Try this... First make sure you are using PROcede Reader 2.0 if your running v2. Second make sure you have the latest firmware and maps which is dated 2-26-2008. Open up Procede Reader and go in to Comms >> Reset ECU This will clear the procede and put it into boot mode. After this follow the directions that were given by Dustin@Vishnu. Make sure during this that your IGN is in the on position (gas gauge at gas level). You may also want to check your serial connection and make sure it is plugged into the procede correctly.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
