01-10-2017, 12:14 AM | #1 |
BimmerPost Supporting Vendor
3837
Rep 54,338
Drives: F80 M3
TC Kline Racing Camber Plates F87 M2
The all new F87 M Series has completely re-designed front strut mounting design than any previous BMW.
The New TCKR F87 M2 Camber Plates are made with an anodized aluminum main plate, and stainless steel bearing housing, stress link mount and fasteners. This is not the cheapest way to make these parts, but TC Kline Racing in only interested in offering the best quality components possible. The camber adjustment holes offer aprox.1 degree camber change for each position, from the center, (stock), to +2 additional degrees adjustment. There is no provision for caster adjustment because the stress bar mount interferes with that possibility. These camber plates are designed to work with TC Kline Racing coil-over suspension, stock suspension use OEM or Sport type springs(OEM thrust bearing must be transferred over to the new plates) and any coilovers using stock upper strut mounts. These can also be used with coilovers later down the road by adding spools and use the compatible top nuts. $538 Order here: http://www.hpashop.com/TC-Kline-Raci...-CP-F87-M2.htm ***3 hole design pictured*** Last edited by HP Autosport; 01-23-2017 at 12:11 PM.. |
01-22-2017, 07:54 PM | #3 |
3837
Rep 54,338
Drives: F80 M3
bump
ashburyn54624.50 |
01-31-2017, 12:50 PM | #6 |
3837
Rep 54,338
Drives: F80 M3
01-31-2017, 01:28 PM | #7 |
Rep 796
01-31-2017, 01:51 PM | #8 |
3837
Rep 54,338
Drives: F80 M3
02-02-2017, 10:52 AM | #9 |
Rep 796
03-19-2017, 11:35 AM | #15 |
3837
Rep 54,338
Drives: F80 M3
TC Kline Racing camber plates
03-30-2017, 10:29 AM | #16 |
3837
Rep 54,338
Drives: F80 M3
04-08-2017, 11:57 PM | #17 |
3837
Rep 54,338
Drives: F80 M3
Camber plates.
If you are local to Santa Barbara, we install them too! |
