2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning B58 Map 1 Operating Temps
      01-28-2017, 08:37 AM   #1
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
So just did a 20-25 minute trip on map 1 with the JB4 app (Thanks Mike @ x-ph for my BT adapter). I was curious what normal operating temps were for the B58 and couldn't find anything so wanted to post my results and see if anyone else has their own input and numbers to add.
5 minute warmup = 130F
1-2 minutes of driving = 160-165F
10 minutes = 185F
15 minutes = 226F (never went above this temp)
I was in Comfort mode/map 1 the whole time, outside temp is 35F, and IAT stayed between 45-50F while driving, ~60F when idle
Trans temps were:
5 minute warmup =75F
1-2 minutes of driving = 95F
10 minutes = 108F
15 minutes 120F
25 minutes = 140F
jpnh1424.50
      01-28-2017, 08:39 AM   #2
Joe240
Joe240's Avatar
Forgot to mention only have the BMS CAI and JB4 installed during this run.
      01-28-2017, 07:15 PM   #3
RotorOver
Newer 2er
RotorOver's Avatar
296
Drives: 2017 M240i (Sold)
2017 BMW M240i  [10.00]
10 minutes = 185F
I've been running an OBDLink MX and can tell you in comfort mode engine oil temp sits at 226F most of the time. Coolant usually runs 225-232F. This on a stock engine set-up.
2017 BMW M240i (Sold)
2021 F-150 Raptor
2017 Porsche 718 Cayman S
2017 Audi Q5
      01-28-2017, 08:28 PM   #4
Joe240
Joe240's Avatar
Not sure why but the JB4 app when I select "water" it constantly reads 0F. I was assuming it didn't have a coolant gauge to read.
      01-28-2017, 08:57 PM   #5
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Matches what I've been seeing with Torque app.
      01-29-2017, 06:31 AM   #6
RotorOver
Newer 2er
RotorOver's Avatar
296
It probably doesn't support it. When researching OBD2 apps it seems some didn't support oil temp, but did provide coolant temp. Also, depended on model and year as well.
2021 F-150 Raptor
2017 Audi Q5
      01-29-2017, 10:19 AM   #7
Joe240
Joe240's Avatar
Figured JB4 would have supported them all. It's the b58 version. Only gives oil and trans temp
      01-29-2017, 10:21 PM   #8
NJ-BMW
20
Drives: M240i xDrive
10 minutes = 185F
Trans temps were:
10 minutes = 108F
15 minutes 120F
25 minutes = 140F
Dont have JB4, on my stock i see the same temps as you listed -
10 minutes = 185F
      02-16-2017, 09:16 PM   #9
Blue Streak
Gunny
Blue Streak's Avatar
Drives: '07 E90 335i 6MT, 2016 F10 535
2007 E90 335i  [9.00]
Dang... my n54 engine oil operating temp has always been around 245 f.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
      02-17-2017, 12:07 AM   #10
Joe240
Joe240's Avatar
N54 is the 228 motor right? They don't have the aux oil coolers
      02-17-2017, 06:48 AM   #11
max_k20
Bavarian Love
24
Drives: 230i xDrive
N54 is the 335 engine and some did and some didnt come with the oil cooler. I was fortunate enough to have the stock oil cooler and temperature was always between 210 and 250f. The N54 was running hot !
08 FG2 Civic SI FBO - SOLD
09 E92 335i Xdrive FBO - SOLD
17 F22 230i Xdrive | Alpine White | Coral Red | M-Sport | BMS Intake | JB4 | 666M Rep | M Carbon Mirrors | Roof Rack | Daily Driven
      02-17-2017, 08:22 AM   #12
Joe240
Joe240's Avatar
Ah ok. That does seem pretty hot to run at.
      02-17-2017, 08:54 AM   #13
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
I still do not get how after sitting for 12 hours in 33 degree weather - immediately on startup the coolant is reported @ 47degrees in Torque.
      02-17-2017, 12:05 PM   #14
Joe240
Joe240's Avatar
The B58 motor is designed to retain heat so it can run more efficiently. When a motor is cold, it doesn't get the best mpg/performance and it also pollutes more. That's why they went this route with the B series engines.
      02-17-2017, 12:42 PM   #15
ko113
Drives: m240i
I switched the gauges on the JB4 app this morning to check these temps.
On sport / map 3 I was also seeing oil around 226F, but my trans temp was about 228F. Would temps be different for a manual?
ambient temp ~58F
      02-17-2017, 01:30 PM   #16
Joe240
Joe240's Avatar
ambient temp ~58F
Possibly. I was only driving for about 20-25 minutes total and trans temp hit 140ish. It was also like 35 outside
      02-22-2017, 11:06 AM   #17
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
While that may be so - I was out of town from from Fri-Monday and when I got in the car (5am on Monday morning)- ambient air was 33F - the Torque app still registered 43F - That's after a weekend of not being driven and below freezing night time temps, day time temps were not into the 40's.
I also understand the thermodynamics of why the motor @ operating temp is more efficient, I just don't understand why Torque is reporting temps consistently higher.
      02-22-2017, 11:48 AM   #18
Joe240
Joe240's Avatar
Hmm that is odd to have it reading warmer like that.
2addicts
