2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Drivetrain Malfunction HELP
      01-30-2017, 09:36 PM   #1
STR8-6IX
536
Drives: RWD 528i N52
got this light again today... it seems to only be happening in cold weather and at high rpm (5000rpm+) in the lower gears.
I will take it to a shop tommorow to scan for stored codes.
could this be a battery related issue? the car was shaking pretty bad. I restart and everything is fine.. engine and transmission are otherwise operating study..
      01-31-2017, 06:15 AM   #2
ALPWhite
138
Drives: 2013 Alpine White 535iX MSport
I had the same error as have many others but it always seems to be something different, battery related I have never heard causing the Drivetrain error though.
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
      01-31-2017, 06:18 AM   #3
doublemetreF10
doublemetreF10's Avatar
Drives: '13 F10 535xi N55
How many miles are on your '11 528? Has it ever had the spark plugs replaced?
There's an outside possibility of a battery issue, however if it was shaking it sounds like a misfire, although most ignition misfires I've dealt with were lower RPM issues that tend to be less noticeable at higher RPM depending upon the severity and engine.
Was the check engine light illuminated and/or flashing in conjunction with the drivetrain malfunction warning?
TO SEE THE WORLD, THINGS DANGEROUS TO COME TO, TO SEE BEHIND WALLS, TO DRAW CLOSER,
TO FIND EACH OTHER AND TO FEEL. THAT IS THE PURPOSE OF LIFE.
      01-31-2017, 07:08 AM   #4
midwest 340xi 6sp
midwest 340xi 6sp's Avatar
Drives: 2018 340xi
I had this happen on my 2013 x3 with N20, only happened in cold weather too.
They had to do some sensor replacement and then it went away. I forget exactly which one as its been a few years.
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
      01-31-2017, 08:25 AM   #5
STR8-6IX
536
I guess ill have to get it scanned then.. yes, I did get a check engine light but the CEL along with the malfunction warning was cleared with an ignition cycle. the engine seemed to rev really nicely.. until I got the warning so im not sure its a misfire but I guess ill only know but getting it scanned.
I recently turned over to 72,000 miles. spark plugs are original. no issues other then this.
      01-31-2017, 09:43 PM   #6
doublemetreF10
At the very least, your plugs aren't helping anything.
They were due at 60,000 mi according to the owner's manual. Don't overlook the small basic stuff.
5post
