BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis M Sport Plus 759 Wheels
      01-31-2017, 04:27 AM   #1
ajfoggy
ajfoggy's Avatar
England
1517
Drives: C63s - S205 - Brilliant Blue
Does any one have a tech specs for the 759 wheels??
I have a set of 513m wheels for my F80 M3 that I use for winters and i'm wondering if they will fit the new car?
But need the details of the wheels, I can't find them anywhere.
      01-31-2017, 05:45 AM   #2
HighlandPete
6659
Drives: BMW F11 535i Touring
Remember G30 is following the revised (new) PCD and hub dims as the G11 7-series, so compatibility with older models (even if the ET is compatible) is over.
      01-31-2017, 06:00 AM   #3
ajfoggy
ajfoggy's Avatar
England
1517
Cheers, are you 100% sure then, not questioning you just want to be sure because i'll put them up for sale ASAP if i can't use them
      01-31-2017, 06:09 AM   #4
HighlandPete
6659
Discussed here.
http://g30.bimmerpost.com/forums/sho....php?t=1321330
Originally Posted by lemetier View Post
All BMW are transitioning to:
PCD 5x112
CB 66.56
Began with i3/8 and all CLAR based cars (G11/30 and newer). It saves a tremendous amount of weight in the axles and wheels.
No previous gen wheels are compatible for 5/7er.
The figures are mentioned in other places.
      01-31-2017, 06:24 AM   #5
E90Fleet
South Africa
1312
Drives: BMW
As mentioned above, wont fit
BMW if you are reading, I need a job, Please.
ajfoggy1517.00
      01-31-2017, 08:25 AM   #6
ajfoggy
ajfoggy's Avatar
England
1517
Thanks!!
Discussed here.
      08-17-2017, 05:20 AM   #7
LarryDavid
Drives: white e60
Went to the dealership and tried this the other day. Does. Not. Work.
Oy vey!
Will fix your keys for you at locksmiths leicester
5post
