01-31-2017, 04:39 PM | #1 |
BimmerPost Supporting Vendor
3774
Rep 54,154
Drives: F80 M3
TC Kline Racing Coilovers
TCKR F8x, M2 Single Adjustable Coilover Suspension System
Now you can improve both the handling and the ride quality of your M3 or M4 at the same time! Choose you spring rates, shock rebound adjustment settings, (externally), and ride height from 2" below stock to even above stock if you like. This TC Kline Racing Coilover System includes proprietary valved KONI rebound adjustable struts and shocks, and our super trick VVS alloy springs. Unlike other coilover systems, our rebound adjusters and wide range of spring rates enable a true match to your driving needs and preferences. Encompassing both street comfort and track performance, this kit is unsurpassed in its class. For an even more advanced setup, choose the double adjustable rear shocks. The improved control of the rear suspension enhanses the traction available from turn entry to turn exit - even if you just leave the settings in the softer positions. This kit includes the following: (1) 8741-1484LSPTC - TC Kline Racing / Koni Left front threaded body strut (1) 8741-1484RSPTC - TC Kline Racing / Koni Right front threaded body strut (2) 8241-1200Sport - TC Kline Racing / Koni externally adjustable rear shocks (1) E90/92M3ShockKit - Sleeves and Bushings to install Front and rear shocks (2) TCKFSXXX - Pair of VVS Front Springs in your choice of rate (2) TCKRSXXX.250.10 - Pair of VVS rear springs in your choice of spring rate (1) TCKE90RSA, F8X Rear ride height adjusters - nests into the unibody for perfect fit. (2) Koni Spanner Wrenchs (2) Koni rebound adjuster knobs (1) One pair of super trick TCK F8X or M2 adjustable camber caster plates - with stainless steel bearing housing and strut brace inserts. More photos coming... |
02-09-2017, 11:54 AM | #3 |
3774
Rep 54,154
Drives: F80 M3
02-09-2017, 01:59 PM | #4 |
Rep 3,945
Do you need to re-preload (reset) the bushings?
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
02-09-2017, 02:23 PM | #5 |
3774
Rep 54,154
Drives: F80 M3
No, do not preload the bushings during re-assembly. You will want the suspension loaded when tightening the suspension bolts to factory torque specs. If the pickup point is a bearing, you do not have to worry about it.
03-07-2017, 12:29 PM | #6 |
3774
Rep 54,154
Drives: F80 M3
Some really good news this morning from TCKline Racing. In about 12 weeks TC the new style rear shocks should be out with much more accessible rebound damping adjustments. No longer you have to remove the upper shock mount to make adjustments to your rear shocks!
03-08-2017, 01:37 PM | #10 | |
Rep 244
I sadly was the victim of crime and had my M4 competition stolen off my driveway just over a week ago . The noise of the MPE starting woke me I had both keys so looked a professional car thief crime Long story short now looking to replace the car with either another M4 comp or M2 hence my interest in this thread |
03-08-2017, 01:42 PM | #11 | |
3774
Rep 54,154
Drives: F80 M3
Let me know if you have any questions regarding the TCKline or the Ohlins(I think we talked about the Ohlins in the past). Feel free to PM or email if it's off the topic for this thread. |
11-21-2017, 10:17 PM | #12 |
3774
Rep 54,154
Drives: F80 M3
TC Kline Racing just released their new double adjustable rears with a window for the rebound adjustment. No more removing the rear shocks!
12-16-2017, 01:13 PM | #14 |
3774
Rep 54,154
Drives: F80 M3
12-18-2017, 10:04 PM | #16 |
3774
Rep 54,154
Drives: F80 M3
12-21-2017, 01:10 PM | #18 |
3774
Rep 54,154
Drives: F80 M3
12-21-2017, 05:50 PM | #19 |
Rep 75
Yes, I am very fortunate! TC has been awesome to work with. Having access to data for road and tracks that is proven is a really big plus. Once you have a setup like this, there is really not much else that's needed as most of us cannot out drive the car in stock form.
12-21-2017, 06:16 PM | #20 | |
3774
Rep 54,154
Drives: F80 M3
Enjoy it! |
