Mmp Port Injection Install
02-26-2017, 10:31 AM | #1 |
Rep 246
I installed my MMP Pi the other day. The setup came to me well packed and of good quality. Everything went smoothly without any surprises. Yes, the clamps for the fuel line were not something I would trust but it was solved in about 30 seconds after I walked over to my parts draw and pulled out 2 of my own. It's funny that people have wasted the minutes of there life complaining about such a small over site? I saw them and decided in a half second that I would use my own, and then I continued laying out the parts to do install. As of right now it is put together and installed. I did some walnut blasting while I had things open. One thing I would recommend would be that as soon as the rail is put together, dab a little bit of gasket sealer on the Orin's and then put them in place. Leave it to setup while you remove the intake. By the time it's ready for install, the prints will be in there place and you will have no issues with any coming out of there positions. I'm doing my wiring today and then I will program and do a log.
02-26-2017, 10:36 AM | #4 |
Rep 246
Pi
More pictures
06-27-2017, 10:30 AM | #6 | |
Rep 33
Drives: 2011 335xi Msport
2011 N55 E92 335xi |Pure Stage 2 |GFB Diverter |Pure Inlet|MHD|Fuel-It S2 LPFP|VRSF DP|VRSF CP| VRSF 7.5 Race IC|Cobb Exhaust|BMS CAI|BMS OCC |ER Oil Cooler|XHP S3 |Xdelete |KW V3 Coilovers |UUC Front Sway Bar|UUC Front Endlinks|M3 Rear Sway Bar|Hotchkis Rear Endlinks|Vorschlag Camber Plates |18" Apex Arc 8 RE71R 255/35R18 square |Wavetrac LSD
06-27-2017, 10:41 AM | #7 |
57
Rep 399
im 2011 e92 PS2 as well and have mmp installed as of last week. still trying work out why im running so lean and getting codes but it pulls hard when its warm but trying to work out why it starts up like shit and runs like crap for 10 mins bucking on me
06-28-2017, 05:49 AM | #8 |
Rep 246
Mmp
The port inj is worked nag well but I have had 2 gasket leaks even after being super critical on replacement. Your situation with going lean and starting rough sounds like it could be the same thing. Try and pressurize the system up to 25 psi and see if you here any leaks or see a pressure drop. You'll here it. Other then that the system works as it should so far.
07-26-2017, 02:10 PM | #9 | |
Rep 66
Multiple reports of knockoff injectors being sent in the kit & leaking immediately.
1-er
Staying stock and watching things unfold |
07-26-2017, 05:17 PM | #10 |
63
Rep 314
my mmp pi had 3 leaking injectors (few drops a min) caused rough warm starts. got 3 new ones shipped after i paid for postage and now its all good.
they are bosch "style" injectors, not bosch. i also had a minor gasket boost leak so just added some high temp rtv gasket around the mmp gaskets that fixed that. kit works well after you iron out any potential issues.
Str8 E85 jb4 mhd Trebila tune , RB Next gen Plus, BMS PI, VTT Inlets, RB outlets, vrsf down pipes, 7" vrsf IC, CP, Turbosmart bov, bms pods, NGK sparks,BL coils, Stage 3 fuelIt lpfp, m3 rear guide rods, poly rear sub frame bushes.
07-26-2017, 06:29 PM | #11 | |
Rep 66
Kit works well, after you fix all the crap. And that is the problem with the platform. Accept sub par quality, to save a few dollars.
1-er
07-31-2017, 07:23 AM | #13 |
192
Rep 1,703
08-01-2017, 01:21 PM | #15 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
MMP will replace any defective injectors without a doubt.
He is also switching suppliers due to the issues that are being reported. |
08-01-2017, 03:47 PM | #16 |
Rep 198
I asked this question. From what I understand they could be leaky causing long starts. I was told to check it by removing the manifold and turning the ignition on to get fuel pressure in the line and see if they leak
