2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 535d 2014 - Loud actuator/motor like noise when turning engine off
      02-28-2017, 11:21 PM   #1
tibre
Drives: 2014 535d US
Post 535d 2014 - Loud actuator/motor like noise when turning engine off
Hi folks,
I am getting an unusual noise like an actuator/small motor for about 5-7 secs when switching the engine off. I have a diesel sedan - 535d 2014 (US), I understand it's equivalent to the 530d in europe.
I am attaching a couple of videos with the noise (see here):
https://drive.google.com/drive/folde...28?usp=sharing
Has anyone experienced the same issue? If so, can you provide guidance on cause of the problem and fix? My car is out of warranty and not sure a trip to the dealer is the right next step.
Your time/answer will be appreciated
FA.
      03-01-2017, 06:42 AM   #2
Sight1
Drives: '14 535d xDrive
Mine doesn't do that but curious what the answer is.
      03-01-2017, 10:16 AM   #3
Breach
80
Drives: F10 520dA M Sport
Yikes, this sounds bad. I also hear a sound, like a pump turning off, shortly after engine off, but nothing like the whine and the other sound (which sounds like a fan hitting something) in your case.
      03-01-2017, 08:20 PM   #4
tibre
Well. Took the car to the dealer. It was explained as normal. A pressure release valve doing its job apparently... somehow I am not convinced with the answer. It seems a bit odd for an engine desig like this one to have something as loud as this valve going off every time you shut down the engine.
I do not recall the engine/valve doing that before...
      03-02-2017, 04:35 AM   #5
HighlandPete
6659
Drives: BMW F11 535i Touring
Normal! Don't think so. Never heard a 3.0d making that sound track after shut down. Could well be a pressure (vacuum?) release, but an abnormal resonance as it is doing so.
5post
