M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Battery tender hook up
      03-06-2017, 06:34 AM   #1
rwm001
Drives: MG DCT
What is the best method to hook up a battery tender?
Should I just close the trunk on the wire or can you utilize the cigarette
charger?
Any ideas are welcome.
Thanks
      03-06-2017, 06:40 AM   #2
DivideBYZero
Never underestimate the Home-Bowl
DivideBYZero's Avatar
United Kingdom
484
Drives: F87 M2<E92 M3<E46 M3
Use a gap in the bodywork and close it.
      03-06-2017, 07:04 AM   #3
Bluenose-2er
Bluenose-2er's Avatar
575
Drives: 2017 LBB 6MT M2
I just hook it up under the hood, using the poles provided there, and secure the hood one click. Then there is enough room for the wire without being pinched or damaging any weatherstripping.
Appreciate 3
BMWM5NYC496.00
BMWZ41909.50
ZPrime611.50
      03-06-2017, 07:24 AM   #4
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
This. It's the best method.
ZPrime611.50
      03-06-2017, 07:35 AM   #5
Semi-Poor
Semi-Poor's Avatar
Drives: 2017 M2 Coupe
2017 M2 Coupe Black Sapphire Metallic
BMWZ41909.50
      03-06-2017, 07:44 AM   #6
rwm001
Drives: MG DCT
Thanks for all the help.
The photo makes it crystal clear.
      03-06-2017, 07:49 AM   #7
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
I actually usually use the rear because I back my car into my garage always. I close the trunk down on the wire but it doesn't need to latch!
I do have an outlet on the side wall and may use the front instead.
      03-06-2017, 09:14 AM   #8
David1
David1's Avatar
814
Drives: 09 E92 09 X5
Mine is hooked up under the hood also but I run the wires out behind the hood down the passenger side fender so I can close the hood.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
JMon3y26.00
      03-06-2017, 03:57 PM   #9
Semi-Poor
Semi-Poor's Avatar
I just leave hood open till the next drive.
      03-06-2017, 04:04 PM   #10
M3 Adjuster
Albania
7906
Leaving the hood or decklid up definitely helps ensure that one doesn't drive off with the battery tender attached.
      03-07-2017, 10:34 AM   #11
David1
David1's Avatar
814
I almost did that once!
      03-09-2017, 11:29 PM   #12
Chuck W.
Chuck W.'s Avatar
356
Drives: '95 Porsche 993 Cab
I hard wired my 535I and did the M2 the same way. I ran the wires out of the bottom right air scoop. The wires push up into the scoop when not in use. You will need to add some length to reach though. The charging nuts come off to reveal studs that the rings go right over.
And... I have a small plaque I set on the drivers windshield wiper to remind me to unplug it.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's
1995 Porsche 993 Cab - Mine
2001 Toyota Tundra SR5 Ext Cab - Hay Hauler
      03-10-2017, 06:57 AM   #13
Stu Pedasho
Stu Pedasho's Avatar
Drives: Clearing garage space
Wink
That is nifty. I just used the word "nifty" in a forum post. I'm officially old.
Appreciate 3
Destroya371.00
Chuck W.356.00
///M TOWN16520.00
      03-10-2017, 07:10 AM   #14
Bluenose-2er
575
Though not as visually obvious, if you close it just one click there is an angry red warning light on your dash that the hood is open. I prefer the hood partially closed as I also put a cover on my car. If you drive off with a red warning light glaring at you, you deserve whatever happens
      03-10-2017, 07:32 AM   #15
LinkF1
Drives: 16' MG F87 M2
I have a solution! Why not drive it more?!
JK, great solutions in this thread, hope I never have to utilize them.
      03-10-2017, 02:43 PM   #16
M3 Adjuster
Albania
7906
      08-11-2019, 08:23 AM   #17
cb804
cb804's Avatar
2351
Drives: 340 xDrive, M2C
Reviving an old thread... does anyone know what is needed to do the hardwire like Chuck W. did in his post? Total newb in the area. I have the BMW tender which I believe is a rebranded CTEK.
It comes with clips and cables. I'm assuming I use the round eyelet cables but then need some type of extension to get it to run to the bottom of the grill... where so I get that?
Thanks
      08-11-2019, 04:08 PM   #18
RAM_F30_F87
RAM_F30_F87's Avatar
Drives: 2017 M2 LBB 6MT; 2012 328i 6MT
https://f87.bimmerpost.com/forums/sh...37&postcount=4
      08-11-2019, 05:44 PM   #19
HawaiiShrimp
HawaiiShrimp's Avatar
Drives: 2017 LBB M2 (MT)
Same here. I think this is the best way.
Current Vehicles: 2017 BMW M2 6MT
Future Vehicles: 2016 Porsche Cayman GT4, 2011 911 GT3RS
      08-15-2019, 07:15 AM   #20
cb804
cb804's Avatar
2351
I'm trying to hardwire a battery tender under the hood. Found a extension that will let me connect the tender by running the wire out the grill or by the wiper area. I'm trying to avoid opening the hood each time I want to use the tender.
My problem is I don't know how to loosen and remove the two bolts that the tender connects too. It looks like a six sided star.
      08-16-2019, 12:21 PM   #21
longbeachbluem2
longbeachbluem2's Avatar
Drives: '76 2002 / '17 F87 M2
2017 BMW M2  [0.00]
1976 BMW 2002  [0.00]
2004 Audi Allroad  [0.00]
I have mine wired up in the trunk (pics in other winter hibernation / battery thread). Theoretically the posts are after the battery management device the car has so it should be the same as connecting temporarily under the hood. Someone recently asked me to take better pictures, but haven't remembered to do so each time I drive the car.
https://f87.bimmerpost.com/forums/sh...7&postcount=14
      06-20-2020, 05:27 PM   #22
debug
Drives: m2 competition
I installed my Noco Genius battery maintainer the following way:
Installation notes:
1. I have an extension for the terminal connectors.
2. The nuts holding the terminal connectors are T50.
3. I added the plastic tubing to make it more cosmetic.
4. Charging is done from the hood cowling area without the need to lift the hood.
m2
