17x7 and slicks 225/45 for autox?
03-09-2017, 01:18 PM | #1 |
Rep 9
Hi. I'm from Perú.
I have a wheel set just for autocross: Konig 17x7 but i don't know what tires pick. I only have 2 options: Federal 595 RS-RR 215/45/17 ($127 per tire) or Maxxis RC1 (slick tw 100) 225/45/17 ($140 per tire) Wich of this 2 will be better with the 7" rim? Thanks and greetings from Perú! |
03-11-2017, 08:48 AM | #3 |
Rep 476
I think a 225 rcomp on a 7" wheel is too big. I used to run a 225 on a 7.5" wheel and there were no issues with fitment. Also, not sure if an rcomp is a good choice for autocross. I used to run them on a shorter track that had only a few hard braking zones; it was difficult to get temperature into the tires early in my run.
03-20-2017, 08:37 PM | #4 |
Rep 9,206
I believe that you asked this questing somewhere else already. Anyhow, as Donutz said 215 will be better for 7" rim and Rcom tired probably won't get hot in autocross.
03-21-2017, 12:17 PM | #6 |
319
Rep 378
Hoosier A7 for griiiiiiiiipy AX if you just want to kick your friends collective asses but check with your rules about that type tire SCCA AX rules are strict about tred ware numbers
