03-16-2017, 11:33 PM | #1 |
39
Rep 89
SSR Performance now offering Air Lift suspension and installation!
We are proud to announce that we are now offering Air Lift suspension! If you're looking to purchase or install your air suspension, look no further! With our competitive pricing and years of experience, we are your go to shop! We'll work on any car, make, or model! Whether you drive a BMW, Mercedes, Audi, etc. we'll get the job done. We don't just cater to the BMW enthusiast, but rather to all car enthusiasts. Allow us to be a part of your build! Why choose SSR Performance? With over 10 years of experience in automotive repairs, 5 years of experience with air suspension, and certified master technicians working at SSR performance. There's no reason you should hesitate to take your vehicle in for any work or repairs! With hundreds of air suspensions installations performed, there are no vehicles we can't work on. We make sure that you have your car leaving in the same condition, if not better. Here at SSR performance, we take our time to make sure that every task is performed to exceed your expectations. With high standards to always prevent any future possible issues that most shops don't take the time to prevent. With our experience, we know which parts fail or what future failures may occur so we take our time to prevent it from happening. Unlike most of the other installers we offer upgraded SMC parts on all our kits, for free! (Ask me why this is much better!) We warranty our work! Quality or quantity? Here at SSR performance, we choose quality. With our confidence behind our work, we offer warranty on all installations and honor all of Air Lift's warranties. Whether it is installation error or defective parts, you can rest assured that we will take care of it! Why choose air suspension over coilovers? With Air Lift suspension, you don't have to worry about losing your handling performance. With 30 way adjustability on damping and high adjustability, we can increase or decrease your pressure to change preloaded pressure within the bags. This will allow us to adjust the suspension according to your needs, whether it be show or performance. You don't suffer any loss in handling with Air Lift's double bellow bag design! Air suspension reliability With air suspension, you can expect the same lifespan as traditional struts and springs. Our customers have always loved and enjoyed their air suspension. With little to no maintenance on the setup, you can expect years of durability. All of our installation includes upgraded SMC water traps and SMC check valves, rather than the traditional check valves that are provided with the Air Lift kits. The provided check valves and water traps tend to seize up with condensation and moisture. We avoid this by upgrading all our kits and installations to the best on the market. Designed with plastic and nylon check valves, these parts will never corrode and seize up. Allowing moisture and pressure to be lost. SMC parts are serviceable, simply open them up and clean them. Air Lift struts and bags are engineered to have the best clearance for specific vehicles. Designed for durability and long lasting life. You can expect these struts and bags to last! Why choose Air Lift suspension? *MOST KITS REQUIRE NO MODIFICATIONS FOR INSTALLATION BOLT-ON OEM REPLACEMENTS *MOST KITS OFFER UP TO 3" OF THREADED ADJUSTABILITY Set the strut/shock to your desired length to give you additional lift if you want more ground clearance or that perfect slammed position. This flexibility allows you to tune the suspension to match your needs without giving up precious stroke. *EASILY TUNE DAMPERS WITH 30 LEVELS OF ADJUSTMENT. With Air Lift’s large range of available damping, you can always find a setting to suit your needs. Like it soft and comfortable for boulevard cruising or stiff for ultimate response and roll control at the track? We have you covered *UP TO 3° OF NEGATIVE CAMBER ADJUSTMENT Available on select kits. Degree of camber adjustment varies per kit. *HIGH PERFORMANCE MONOBALL UPPER MOUNTS Maintain the best tire contact patch on the road as possible. Our adjustable camber plates not only help you achieve a show winning stance, but also help you dial in the optimum geometry for maximum chassis performance. *Drive it. Show it. Track it.™ No other suspension gives you the ability to comfortably drive you car daily, slam it to the ground for show-winning stance, or tear up your favorite race track: all with the touch of a button and twist of a knob Air Lift v2 *8 USER PRESETS Program your favorite ride heights and easily adjust suspension dynamics to compensate for additional passengers and cargo. Set one for “all up” one for “all down” and anywhere in between. *Digital pressure gauges Integrated digital pressure gauges to display in-tank pressure and pressure inside each individual air bag *Rise on Start Turn the key and the system will take you right to your programmed ride height. The sleek V2 controller is protected in a rugged, rubberized coating to help protect against the occasional drops and scratches. Display readout shows, individual corner air pressure and tank pressure. You can select your pressures to be displayed in PSI, or for our friends across the pond, we now have an option for BAR!! To give you the ultimate in personalization of your system we have loaded the multi-color display with 512 color combinations! Believe it or not all of this technology fits in the palm of your hand and only takes one wire to connect to your wire harness. Not only does the V2 give you 8 different presets to tailor to your ride heights needs, but it also “learns” your vehicle to provide incredible accuracy with every push of the button. As you roll low, the V2 will constantly monitor your pressures and adjust accordingly to your presets. V2 also allows you to control your system manually, for the ultimate in independent 4 corner adjustment. With the raise on start feature, you won’t even have to touch the controller! Fully laid out? Raise to your ride height as soon as you turn on your ride and you’re ready to go. You want diagnostics? Well V2 has diagnostics! With a touch of a button you can check compressor performance and compressor run times. The system will also alert you to a leak, a low pressure situation, communication failure or if there is something wrong with your valve. Installation could not be easier! Mount your components, hook up 3 wires, plug in the OEM quality harness and you are ready to go. The detailed instruction manual will take you through the calibration and ride height preset process. Each V2 is 100% function and leak tested at the factory after assembly, so you can cruise the streets in confidence! One of the best features of the Air Lift Performance Auto Pilot V2 is that it is proudly made in the United States of America! Air Lift 3P/3H *Controller Both systems come with the Air Lift Performance 3 controller, a device that is truly amazing to hold and to use. *Free Mobile App Take full control of your 3H/3P system with a FREE mobile app with no additional hardware needed, for all compatible devices. *Fully Integrated Manifold By combining the ECU, pressure manifold, and Bluetooth module into one compact unit, the new manifold takes up less space than multiple components. *5 Custom Presets The system quickly adjusts to and maintains height and/or pressure presets with the push of a button. *Height + Pressure The system comes with everything needed for height and pressure control up front, for the best value. Start driving in pressure mode and install height sensors later, without the need to purchase an upgrade. *Height Sensing Technology Height sensors give the system the ability to automatically adapt to changes in vehicle load. *Anti-Cross Loading + Axle Equalization With the combination of pressure and height sensing technology, 3H can achieve the correct height without radical differences in pressure. *Show Mode Turn your vehicle off and continue to control your air management via the controller or FREE mobile app. *Rise on Start Turn the key and the system will take you right to your programmed ride height. Installation rate: (All cars vary as some vehicle requires more labor than other.) We can also do custom setups, accordingly to your likes and needs. Please contact us for more information and pricing Turn-around time: You can expect 3-5 days on basic installations, but expected time will vary based on any upgrades or additional work you want us to perform Please do not hesitate to contact us if you have any questions that we were not able to answer in this thread! There are no dumb questions! Please PM me, call us (800) 438-2808), or e-mail us at info@ssr-performance.com for any questions or inquiry. We are not limited to Air Lift kits, we offer Accuair and AirREX as well. Contact us for more information and inquiry Last edited by Mike @ SSR Performance; 03-16-2017 at 11:43 PM.. |
