Changed my belt! Soo easy!
03-19-2017, 08:07 PM | #1 |
Ether
59
Rep 163
Drives: 2023 X1 Msport
Today I decided to change my belt I had a oil filter housing leak that I decided to fix myself. Very easy but time consuming. Oil had leaked on to the belt and the belt developed a nasty squeal. Long story short I was able to swap it on my n55 e92 in about 15 minutes. Very easy to get to I just had to buy a breaker bar and a torx 60 for the tensioner. I hear the dealer charges 2 hours labor what a rip off.
03-20-2017, 05:05 AM | #2 |
No 55mph
1622
Rep 8,476
Probably that 2hr charge includes replacing the Belt Tensioner & Idler Pully - which, depending on your mileage, you should have prolly done when you replaced the belt - even with replacing both of those it doesn't take 2 hrs...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
vivaladav59.00 |
03-20-2017, 07:27 AM | #3 |
Ether
59
Rep 163
Yea I'm sure replacing those two things wouldn't take more than additional 20min provided you have the right tools. I also don't have an oil cooler so I have a lot of room to work with
03-23-2017, 06:48 AM | #4 |
Rep 2,015
I created a DIY for the N54, but not sure....on N55, but recommend replacing Belt, Tensioner and Both Upper and Lower Pulleys.
03-23-2017, 07:21 PM | #5 | |
Ether
59
Rep 163
03-23-2017, 07:41 PM | #6 | |
Ether
59
Rep 163
03-29-2017, 01:51 PM | #9 |
Rep 1,416
How money much did that set you back?
04-04-2017, 07:57 AM | #10 |
Ether
59
Rep 163
04-04-2017, 09:35 AM | #12 |
Rep 2,015
Not a Mechanic by any means.
You are probably right, but tried looking up a DIY when I was tackling this, and at that time it came up as a replacement item. My Belt was moving on the upper pulley approx 1/4 to 1/3 inch. So, i did not want to risk it and decided to replace all. It was $26 more....so....no brainer there. |
04-20-2017, 04:26 PM | #13 |
480
Rep 1,600
New engine 9000mi ago and leaky oil filter housing gaskets already?
Did they replace a complete new engine or block and pistons only? Pulley bearings on these motors tend to wear quickly and if you've had an oil filter housing leak and repaired it, chances are all that brake cleaner you used to degrease the soiled areas has also found its way into the supposedly sealed pulley bearings so you end up with a new noise afterwards. All of mine have a bit of play but the belt is only shimmying about 1-2mm at the moment. If the belt jumps then it will get eaten by the engine. It wraps around the harmonic balancer and pushes in the front main seal |
vivaladav59.00 |
04-20-2017, 04:45 PM | #14 | |
Rep 3,875
Drives: 330i, 135i
Yeah me too. I replaced my belt, tensioner and pulley. 1.5 hours save lots $$$ 144k miles. Had original belt plus mine too was coming off the pulley. N52 |
04-24-2017, 02:46 PM | #15 | |
Ether
59
Rep 163
