Crap, am I bumped out of the stock autocross class?
03-29-2017, 02:16 PM | #1 |
Rep 1,191
Drives: 2009 BMW 328i Wagon
Get ready guys and girls, I'm about to ask a stupid question:
I'm totally stock, with the exception of a set of Bilstein B6s, and a set of rear Style 161s with 245's on them all around. Does the 17x8.5" wheel on the front mean that I'm out of the stock class, even though that's an OEM wheel size for the back? |
03-29-2017, 03:48 PM | #2 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Yes. In most BMW CCA clubs, coilovers are 5 - 7 points. Switch tires and you are in the next class.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
03-30-2017, 05:17 AM | #3 |
729
Rep 1,815
B6 are the equivalent of stock dampers. They are used as a direct replacement and not considered an upgrade.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
03-30-2017, 06:50 AM | #4 |
Rep 1,191
03-30-2017, 06:51 AM | #5 |
Rep 1,191
03-30-2017, 07:07 AM | #6 |
729
Rep 1,815
I doubt they will bust out a wheel caliper and the cars specs to compare.
04-01-2017, 05:56 AM | #7 | |
Rep 3,334
If you have a sport package car, it probably came with 8" front and 8.5" rear widths (and likely ET34 front and ET37 rear), so to remain eligible for street class, you'd have to run these widths. If your car was a non-sport pacakge, it likely came with 7" wheel width all around with ET34. In which case, you'd be required to stick to 7" wheels. You can "upgrade" a package and remain legal, but you actually have to change every single thing on the car for that package (i.e. sport package change would required OE ZSP springs, shocks, sway bars, seats, steering wheel, etc, etc). It's common when running required staggered widths to still run square tire setups in street class. So, the answer to original question is yes, no stock/street class for SCCA events or those run under SCCA rules. If it's our local club (THSCC), I've run THSCC autocrosses since the 1970s, and most everyone is pretty easy going on something like your situation *unless* you're going to place high, either in class against others or PAX overall -- then it makes sense to not be "that guy" and put people on the spot. However, talking with one of the autocross VPs ahead of time makes sense. Regards, Chuck
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 Last edited by CSBM5; 04-01-2017 at 06:02 AM.. |
Antetokounmpo1549.50 |
04-03-2017, 01:35 PM | #8 |
172
Rep 392
I agree with Chuck's last point. Are you trying to compete regionally or even nationally? If you're just going to autox as a matter of fun and competing with yourself, then for the most part people aren't going to fuss about the classing unless it's blatantly out of class.
If you want to seriously compete, then I would go read the SCCA rules very carefully and find out the answers to your questions as well as exactly what you can do within the class you want to be in. |
04-03-2017, 02:00 PM | #9 |
Rep 212
If its local, nobody will care. Beat class all the time, maybe someone might bitch.
2011 335i Sport, M3 control arms front/rear, ECS Tuning rear trailing arms, Bilstein HD's, StopTech BBK, Drexel LSD, Dinan camber plates, FBO's with Cobb Stage 2 tune, Corsa exhaust, 18x9 D-Force, 255/35 R-S4's
04-03-2017, 02:05 PM | #10 | |
Rep 1,191
As for whether I'm competing or not, I think that I'm not going to be very competitive seeing as this would be my first autocross, but it is a race, right? I wouldn't go to a 5k and walk it, so I'm going to try my best at this one. I just don't want to piss anyone off by cheating. |
04-03-2017, 02:19 PM | #11 | |
Rep 3,334
As a novice, you'll be placed in novice class and PAX'd against all other novices. It's up to the event GM and/or Autox VPs how to class you and whether to say that 0.5" means bumping a novice into street prepared or not. Different clubs will handle this differently. Hence why I mentioned contacting one the Autox VPs if the club you're thinking about is THSCC. Novice school is May 6th. We usually have an excellent school with good feedback from students. I've autocrossed for over 40 years and instructed for 35+, autox and track. Ages, and I mean ages ago, when I was autox chairman for a large chapter of the CCA, I would usually side with the first time driver on something like this (i.e. tell you to run stock class) with such a minor issue, but point out that you would need to line up with the class rules for future events.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
04-03-2017, 02:24 PM | #12 |
Rep 3,334
Sorry, forgot to post link to contacts at THSCC: http://www.thscc.com/index.php/club/contact-us
Current Stable:
04-03-2017, 02:54 PM | #13 | |
Rep 1,191
I was going to try to do the autocross next weekend at Cary Towne Center next weekend. You going to be there? |
04-03-2017, 03:05 PM | #14 | |
Rep 3,334
Current Stable:
