2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum worth replacing with ACS springs on LCI F10 550 with sport suspension (704)
      04-10-2017, 10:10 AM   #1
gestut
Drives: 2015 M5
I have searched but, couldnt find anything on this topic, I found one line that says there was not much difference in handling going from LCI sport suspension (704) to ACS springs except lowered look... Is this true anyone with LCI sport suspension 9704) has replace springs and seen a noticeable difference in handling? mine is 2014 F10 550 and I have 704 sports suspension as per vin check
      04-11-2017, 01:03 PM   #2
xxpanipuri
Drives: 550i
i have the same car with same suspension, and I installed the ACS springs about a year ago.
Here's my thoughts
1) 1" lower - which is just enough for me.
2) the ride is similar to stock, slightly stiffer.
3) HUGE IMPROVEMENT here, eliminated the brake drive and acceleration squat, and the general floatiness of the suspension. When i'd drive it on our crappy bay area roads with the stock suspension, at 65mph (you cuz i always go the speed limit) , i felt the car wasn't too planted at all.
IMHO the look and performance after installing the ACS Springs was worth it for me, I don't do track time in this car, but for my spirited mountain runs, she handles fairly well for what i throw at her. At some point i may do Coilovers, but for 850 installed these springs were a good compromise, this is how a bmw should come FROM the factory.
oh and NO bounciness that is often associated with lower cost springs, so the additional cost of the springs is also worth while.
      04-11-2017, 01:53 PM   #3
gestut
Drives: 2015 M5
Thanks panipuri! good feedback here, I wanted to see if it made a difference in handling on twisties etc, I dont track either!!, I already have installed H&R sway bars kit, and that made a difference on the roll, but I am still missing something
like your ride height
btw where did you get the springs from , thanks
      04-11-2017, 02:14 PM   #4
STR8-6IX
536
Drives: RWD 528i N52
good performing, low profile rubber goes a long way with overall handling and performance.
if you already have m sport suspension, new springs will probably not make such a big difference, but it is most likely okay to do.
      04-11-2017, 02:36 PM   #5
xxpanipuri
Drives: 550i
My shop was able to source them, or you can call ACS directly, their NA distributor is in SoCal, lmk if u can't find it i can dig up the contact info
where did u get the h&r sways from?
      04-11-2017, 03:26 PM   #6
gestut
Drives: 2015 M5
are you speaking from personal experience ? i read that same thing somewhere else but panapuri statement is different and positive so now i am thoroughly confused
i do have michelin pilot super sports now
      04-11-2017, 03:27 PM   #7
gestut
Drives: 2015 M5
ok will try to find acs direct...
i got the sway bar kit from ecs tunning and it got shipped direct from H$R
      04-11-2017, 04:18 PM   #8
STR8-6IX
536
the best setup for your car is by going aftermarket.
I recommend either koni or bilstein sport struts with ACS springs. Eibach springs are also good.
      04-11-2017, 04:28 PM   #9
xxpanipuri
Drives: 550i
what happens to EDC if you go with koni or bilstein shocks? is there an EDC Delete?
      04-11-2017, 04:47 PM   #10
bigshout
Drives: F10 535i
Eibach make ACS springs and are very popular here in Europe. I've always gone with Eibach as they come in cheaper than. ACS but with a similar performance and same quality.
      04-11-2017, 05:28 PM   #11
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Here's my thoughts
That looks perfect you must be sitting on 20s
How long did you wait before you did alignment
      04-11-2017, 07:30 PM   #12
xxpanipuri
Drives: 550i
ACS are manufactured by eibach, but they are manufactured to ACS' specs. I've never used eibach's so i can't speak to the quality of the ride on those. but i've been VERY impressed with the ACS Springs...
      04-11-2017, 07:32 PM   #13
xxpanipuri
Drives: 550i
yes they are 20"s.
I waited about 400 miles i believe as per the shops recommendation, to insure that the springs were fully settled...
      04-29-2019, 10:54 PM   #14
DML550i
Drives: 2013 BMW 550i MSport
Lowering 2013 550i
Hi xxpanipuri- I am also located in the bay area and agree, roads are terrible! do you still have the car and have you installed coilovers since this post? I have the same color car, exact model! What is the make of your wheels? What size tires?
      04-30-2019, 05:03 PM   #15
xxpanipuri
Drives: 550i
hey man, the crappy bay area roads, cracked/bent one of my vorsteiner vff102 wheels that are on the car in that pic
at 40k miles now and i'm still on the springs, the suspension isholding up well...
here's how she sits now...
      05-02-2019, 11:29 PM   #16
Freak1c
Freak1c's Avatar
145
Drives: 2018 M3 ZCP MW
ECS TUNING sells them, cheaper than going directly through ACS.
      05-06-2019, 12:17 AM   #17
DML550i
bummer on the wheels, but it looks really good. Did the springs settle and lower a bit more or did it stay the same over the years? What shop did your work? I was thinking of having the KW adjustable coilovers installed as i want to get rid of the rake in the rear and level it. what do you think?
5post
