BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Tire Pressure
      04-16-2017, 09:18 AM   #1
VZehn
VZehn's Avatar
Drives: 2014 BMW 540i
Tire Pressure
2017 540i xDrive M Sport
All season tires (Continental ProContact 245/40 R19 98H M/S)
- Vehicle Status on iDrive recommends 39 psi Front and 47 psi Rear
- Sticker on door jamb shows 35 psi Front 41 psi Rear
I trust the door sticker more than the computer, so I think I will try those settings. Suggestions?
By the way - this is my first BMW that enables you to view the tire pressures at each wheel. About time.
2017 540i xDrive Carbon Black/Canberra Beige
former beasts: 2014 M5 CP Black Sapphire Metallic / Silverstone; 2006 M5 Black Sapphire Metallic / Portland
      04-16-2017, 09:26 AM   #2
babaikram
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
United Kingdom
512
Drives: .
You have to specifically tick the kind of tyre your are using on the options for current tyre on drive and also tick whether is full laden or partially lade for the idrive to recommend correct pressure. If your tyres are not listed then you have to tick: other tyre in the option for current tyre
      07-31-2017, 01:03 PM   #3
Ab3_Fr0man
39
Drives: G30 540i
2017 540i  [0.00]
2011 535xi  [0.00]
There is no listed option for 20" tires only 17"-19" options... - Why would they not list a stock / factory available size?
      07-31-2017, 11:46 PM   #4
emre
emre's Avatar
Turkey
85
Drives: G30 540i xDrive
I do get the 20" option listed.
Recommended pressure on my screen is 39 psi (F) and 39 psi (R) when cold. Goes up as i drive of course.
G30 540i xDrive M Sport MPPSK / BM3
      08-01-2017, 08:22 AM   #5
Ab3_Fr0man
39
Drives: G30 540i
2017 540i  [0.00]
2011 535xi  [0.00]
well shit.... I wonder why i don't have it listed as an option?
      08-01-2017, 11:34 AM   #6
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Did you try the Special Approval Setup Menu?
      08-01-2017, 11:36 AM   #7
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
The iDrive values will be much more accurate now. Do you by chance have Maximum Speed >160km/h selected?
      08-01-2017, 05:11 PM   #8
Ab3_Fr0man
39
Drives: G30 540i
2017 540i  [0.00]
2011 535xi  [0.00]
I will investigate further and see what is available in the special approval menu.
Thanks!
5post
