2010 2011 BMW 5 Series Forum F10 white smoke from tailpipe |
04-17-2017, 07:07 AM | #1 |
19
Rep 33
So I was car shopping the other day & was planning on using my 2011 BMW 550ix as a trade-in. The estimator came in with a lowball price & said there was white smoke coming from both tail exhaust's. I said I have never seen any before so we went outside & he started the car while I stood behind it & after about 2 minutes of letting the car idle white puffs of smoke started coming from both exhaust pipes. He said that is a very expensive fix. The car runs perfect. Can anyone help me understand this? thanks
04-17-2017, 08:06 AM | #2 |
9159
Rep 14,521
white smoke is coolant/water...blue smoke is fuel usually...and gray or black smoke is oil. could be just condensation in your exhaust pipes tho?
04-17-2017, 08:57 AM | #3 | |
19
Rep 33
So the coolant guess would make sense. About 2 weeks ago I got a message on the display to add to my coolant so I added 3/4 of a quart of anti-freeze. I then drove from Florida to Ontario, Canada & checked the anti-freeze level & it had dropped a little so I again topped it off. |
04-17-2017, 09:06 AM | #4 | |
9159
Rep 14,521
04-17-2017, 09:22 AM | #5 | |
19
Rep 33
04-17-2017, 10:11 AM | #6 | |
9159
Rep 14,521
04-17-2017, 11:12 AM | #8 |
9159
Rep 14,521
i was thinking about the seals too on the turbo! i think you're right on the black and blue smoke now that i think about it. i know when i was running rich i thought blue smoke was the fuel? nevertheless he's got white smoke so we know it's water/coolant
04-17-2017, 12:04 PM | #9 |
Rep 785
Yup, but it seems odd that it starts only on idle. That symptom right there would point to valve stem seals. OP, are you sure the smoke doesn't have a light blue tint to it?
04-17-2017, 12:44 PM | #10 | |
ZEROdoubleZERO
228
Rep 659
04-17-2017, 07:47 PM | #11 |
Rep 102
It's probably your valve seals which means you are burning oil. Do you smell a burnt oil smell after idle? Have you had to add oil in between oil changes?
You can search other threads and see that white/gray smoke when revving engine after idling means valve seals failing. Repair approx. $5k. |
04-17-2017, 08:30 PM | #12 |
Rep 785
if it does turn out to be valve seals, find a good Indy that has the AGA valve kit.
Shops here in SoCal charge 2,500 for the job since it can be done without removing the engine with the toolkit. |
04-19-2017, 07:28 AM | #14 |
19
Rep 33
Been very busy at work lately & haven't had time to do any follow up on this issue. I will look for a good indy & see what they say. Still love the car & want to keep it around for a good long time.
04-19-2017, 02:35 PM | #16 |
19
Rep 33
04-19-2017, 02:37 PM | #17 |
536
Rep 2,825
04-22-2017, 03:27 PM | #18 |
Rep 795
Makes sense to keep it as long as it doesn't totally crap out on you, but I wouldn't spend much time/money/energy trying to fix it quite frankly...
