Tune suggestion ?
05-02-2017, 12:23 AM | #1 |
217
Rep 1,909
Tune suggestion ?
Hey folks, we have the x5d 2012, m57 ... About 10k miles ago we took a trip to Toronto and got all the goodies from Jarek etc .. I paid him of for stage 2.5 but he suggested to custom down tune it to 2.25 for reliability and since x5 is a bigger vehicle EGTs would be higher at 2.5 which is mostly for 335d...
All that said and done I need more power Andy from dallas will charge 300 bucks and get 2.8 .. Do you guys suggest it? Am I looking to damage something in the truck ? It has 54k miles on it, abc deletes, race pipe installed .. Reliability is very important because we haul kids and Chicago winter is brutal
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
05-02-2017, 07:41 AM | #2 |
Rep 122
I don't know anyone with an X5 that is doing it, but if high EGTs are a concern with the 2.5 or 2.8 you could always run water/meth inj., plus you'd be adding a few more horses with that alone. I think an upgraded intercooler may be in order also.
05-02-2017, 08:11 AM | #3 |
Know's a guy that know's a guy...
5637
Rep 1,905
Contact BPC. They are actively working on a X5d at this time.
05-02-2017, 04:37 PM | #4 |
Rep 3,557
Jess has a pretty healthy X5 I've heard but he isn't hauling kids. His winter is likely as bad or worse than yours (upstate NY).
Agreeing with JTC1, Meth + better IC makes sense if you must have more power. Just the meth alone might be enough power though. Do you pull anything? That would be what would create higher EGT. |
05-02-2017, 05:48 PM | #5 | |
217
Rep 1,909
05-03-2017, 06:20 AM | #7 |
Rep 128
Don't be afraid of meth. You get the power that you are looking for and it should help keep it clean which theoretically helps reliability. It's really not as complicated as everyone makes it sound either.
05-03-2017, 07:32 AM | #8 | |
BRR tuned
220
Rep 646
if comes to the family and safety leave it as it is and be happy with what you have. you can always buy a side car and do what ever the heck you want to do to it and not worry about the wife and kids being stuck on the side of the road. from my own personal experience it is best to have a "hotrod" and not drive it everyday. my last truck was a Toyota Xrunner I installed a turbo and all the extra junk.. I started to feel it was not fast enough and upped the boost.. then that wasn't enough.. it was in need of some large up keep due to all the mods, so I bought a side car... I then started to appreciate the truck more and my need for it needs more was gone because driving a 70hp civic put me back in check |
05-03-2017, 08:10 AM | #9 |
2125
Rep 3,368
I run JR stage 2 on my 335D. Unless you go with a 2.8, IMO there is not much difference between a 2 and a 2.5, so the fact that you are at "2.25", quite frankly I doubt you'd notice the difference vs a "full" 2.5.
As others have said, an X5D is plenty fast and safe as a family hauler in stock form. The tune should be viewed as a reliability upgrade for your situation. Leave the speed and power factor for the "fun" car. |
05-03-2017, 03:06 PM | #10 |
217
Rep 1,909
I have a fast car .. question remains what can hurt if I go 2.8 ? the harmonic pulley & Water Pump will still need to be replaced regardless of tune
Meth is out coz I saw someone catch fire due to that **** hows a jbD with 2.25 power hungry yeah!
05-04-2017, 09:01 AM | #12 |
Rep 1,157
Well it's counter-intuitive. A high powered tune basically screams extra wear, and more chance for failure. On the other hand, everyone running 2.8 is not having any issues, and the deletion of emissions components significantly increases reliability. I understand why people are skeptical.
05-04-2017, 10:07 AM | #14 | |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
The faster you make it the less reliable and more expensive the ownership of the vehicle becomes. If you want to go fast you can buy an fully loaded 07 335i for 7k. Spend 7k in mods and you will be plenty fast.
05-04-2017, 01:05 PM | #15 | |
389
Rep 1,623
I haven't installed water injection yet but, I have enough stuff in the barn to install and plan on it soon. 20-40whp, and a bunch of torque for next to nothing and it helps with CBU... seems like a no brainer. I don't see an intercooler being necessary. I'd install water injection before I'd mess with an custom intercooler install. In my 335d, I made 393 and 611 to the tires with stock intercooler, air box and water/meth. Last edited by 335dsleeper; 05-17-2017 at 05:20 PM.. |
05-04-2017, 01:24 PM | #16 |
Slow.
3782
Rep 7,151
Custom IC should flow better than stock especially when you are pushing 2x the air through it. So there will be gains based on flow on top of the IC cooling the intake charge better. I do agree Meth will be easier to install as no one makes a IC kit for the X5 as far as I know.
50/50 is still flammable or so says the internet. I run 50/50 in my car but i've never tried to set it on fire. Easy enough to test but I have no reason not to believe the internet.
05-04-2017, 02:39 PM | #17 | |
389
Rep 1,623
Of course it should flow better than stock but is it needed? What is to be gained HP vs $? OP, I recommend logging CACT and EGT before I'd go with a custom intercooler, again considering the HP vs $ ratio. If the OP is doing prolonged pulls where he's seeing a significant increase in IATs and if he has 1k + burning a whole in his pocket... sure, go ahead. I haven't seen the data that suggests it's needed based on my experience with my BPC Tuned X5.
2 x the air flow seems like a lot. No? You are correct, the internet states 50/50 is flammable. That said, a lot of washer fluids are considered flammable according to their MSDS, many with far less than 50/50 but, just about everyone has washer fluid in their car. Here are a few videos of 50/50 flammability testing. Of course one could argue the testing standards in these videos but... interesting nonetheless. OP, best of luck with whichever route you chose. Quote:
05-04-2017, 03:02 PM | #18 |
Slow.
3782
Rep 7,151
BPC seemed to get great gains with their IC: http://www.e90post.com/forums/showthread.php?t=1377806 If you can buy one and install it yourself it's probably worth it.
but again meth is easier to install most likely.
05-04-2017, 05:14 PM | #19 | |
389
Rep 1,623
Yup, and for $1200. HP vs $
Interesting enough, many people have made more power and torque through the stock intercooler. That said, no one is arguing the benefit of a larger intercooler, especially on longer, multiple gear pulls or on a dyno where the airflow though the intercooler is different than on the road. On the road and at the power level you cited, the dyno gains might be negated on the road. This is why I suggest the OP log his CACT and EGT. That's the only way to see what's happening and to determine if the cost is worth the effort to the OP. The OP could install a simple meth kit and run 50/50 mix or could run -20 washer fluid. At any rate, the cost for WI is less and there are added benefits. Not to mention many pick up close to, if not more than 40whp with 50/50. Quote:
