M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Rear differential recall replacement service
      05-02-2017, 10:34 PM   #1
dasblack
Drives: BMW M2
To anyone who had a defective rear differential replaced, did you get your car serviced after breaking in the rear diff? I ask because at 1,200 miles BMW changes rear diff fluid.
Thanks,
Brian
      05-03-2017, 06:15 AM   #2
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
Thanks,
Brian
Yes, if your differential was replaced, you have to do another 1,200 mile service on it and observe the proper break-in procedures during that time.
PS: mine was, but during the period it was mandatory, so the first diff never even got broken in.
      05-03-2017, 12:26 PM   #3
reppucci
340
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
2016 M2  [0.00]
1995 M3  [0.00]
2006 Mini Cooper S ...  [0.00]
2004 A6 2.7T  [0.00]
1994 325is  [0.00]
Mine was replaced at about 1000 miles under recall. Got my 1200 BI service done then.
The diff fluid needs to be replaced at 2200 miles( 1200 miles after new diff put in).
I still can't completely get on it to allow the new diff to "breakin".
I did however have car on the track just before the old diff was replaced.
There is some controversy on these forums about the M2 1200 mile breakin. Seems the M2 1200 mile breakin service is more for the M diff than for the engine. M235 doesn't have the same 1200 service IIRC! M3 and M4 do also but they may also undergo ECU reprogrammed to increase power and rev limit.
It is confirmed that the M2, aside from Launch control in DCT, has NO ECU power or rev limitations removed at the 1200 mile BI service
      05-03-2017, 03:43 PM   #4
bim2er
bim2er's Avatar
Drives: '18 Mineral Grey M2
Overboost supposedly is enabled, but that has been disputed.
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
reppucci339.50
Seagull288.50
      05-03-2017, 05:58 PM   #5
akkando
akkando's Avatar
5865
Drives: 17 M2 DCT LBB,11 e90 M3 ZCP IB
Is there any way to even know if they enabled anything like that or not?
      05-03-2017, 11:06 PM   #6
dasblack
Drives: BMW M2
Hmm, that's what I thought too but my service adviser said I didn't. I asked BMW genius about it but they said speak with my service adviser....
      05-04-2017, 06:41 AM   #7
gmzanatta
gmzanatta's Avatar
1823
Well not quite...the motor itself is broken in from WOT testing at factory, HOWEVER, the M diff and the remainder of the drivetrain components do have to be broken in.
But as you said, the M diff if by far the most important part of that puzzle.
reppucci339.50
      09-14-2017, 01:09 PM   #8
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
So my car is getting the diff replaced now. I asked my service advisor if the 1200 mile break in service was required for the new diff and he said that it was, but I did not have to keep the car under a specified rpm/speed as that was for the engine only.
      11-25-2017, 03:23 PM   #9
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
What is your build date?
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      11-28-2017, 11:47 AM   #10
twin fed
Doc Brown
twin fed's Avatar
1176
August 2016
      09-24-2020, 10:21 AM   #11
Q_Subsub
Drives: 2018 M2 AW 6MT
How is your car now? I just got my diff replaced under warranty and the SA told me that I have to re-do the break-in procedure again...
      09-25-2020, 07:00 PM   #12
twin fed
Doc Brown
twin fed's Avatar
1176
The car is fine and has been since the replacement. In fact I completely forgot that I had it done. But yeah you do have to do the break in process all over again. But like I said prior, you don't have to keep it under a certain speed or rpm that was only for the engine.
m2
