BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > E92 335i advice on parts.
      05-12-2017, 06:58 AM   #1
Prev
Prev's Avatar
Guernsey
9
Drives: 2009 E92 335i M-Sport 6MT
Hi All.
I would post under general or one of the other sub forums, but this one seems to be the sub forum with the most knowledge.
Took my 09 E92 335i to Le Man's, France in August last year for it's first trackday. Had a great two days and felt the car in standard form handled it's self well. But.... always a but when your a car guy, it had some down falls. So i'm after some handling mods. So I have roughly $4k to play with for upgrades. $1800 of that has been earmarked for the Quaiffe LSD. Looked at wavetrac but the UK dealer wants close to $3k to fit the LSD in my pumpkin, so they can shove that.
I've got MSport suspension on the car and to be fair i'm happy with that currently. Fitted yokohama AD08R tyres and these have been fantastic. Discs/pads/braided brake lines have been bought and ready to be fitted.
So on to you guys, what else? Solid rear sub frame bushes? Diff lock down? What i'm looking for is to sharpen up the handling. Cooling i'm working on, as i've got the factory oil cooler and looking at adding a second oil cooler the other side. I've prob forgotten something, but will update this as I remember. So if you could recommend parts and the make that would be great.
Cheers
Tom
2009 - E92 335i with a touch of MHD.
Previous:
2007 - MK1 Mazdaspeed3
1997 - Nissan R33 Skyline GTR V-Spec
2000 - Nissan Patrol LWB
      05-14-2017, 10:50 AM   #2
feuer
feuer's Avatar
Drives: wife crazy!
-m3 front control arms
-m3 from front sway bar
-camber plates
-rear subframe bushings
-rear upper shock mounts
-PPk coolant radiator instead of 2nd oil cooler
-vwetish diff lockdown
-transmission mounts
All will make the car sharper
Appreciate 3
bNks334426.50
Prev8.50
Volasko705.00
      05-14-2017, 04:52 PM   #3
Prev
Prev's Avatar
Guernsey
9
-camber plates
Thanks for your reply. Will look at getting those ordered.
I incorrectly said I had discs. I have pads and braided lines, but I have yet to get discs. Any recommendations?
Cheers
Prev
Previous:
      05-15-2017, 07:58 AM   #4
bNks334
bNks334's Avatar
427
Drives: '11 135i (N55)
-camber plates
This should be a sticky lol these are all relatively easy and cheap mods that should be on everyone's list!
feuer4275.50
Prev8.50
      05-15-2017, 08:24 AM   #5
feuer
feuer's Avatar
Drives: wife crazy!
I have had good experience with Zimmerman's.
Prev8.50
      05-16-2017, 10:40 PM   #6
Cloud9blue
Cloud9blue's Avatar
Drives: around the potholes
at the very least get the m3 control arm for the front end and stiffer rear subframe bushings. your car will feel like a different car afterward.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization
Prev8.50
feuer4275.50
      05-18-2017, 09:45 AM   #7
Prev
Prev's Avatar
Guernsey
9
Right lads. I have put together a shopping list and about to "pull the trigger" as you guys say . Below is my order list from ECS tuning. Let me know if you think anything should be changed.
TRW M3/1M Front Control Arm Upgrade Kit
Turner Solid Rear Subframe Bushing Set
BMW Front Sway Bar Installation Kit - 28mm
Dinan Camber Plates
Powerflex Performance Polyurethane Rear Upper Shock Mount Set
UUC Transmission mount bushings - Black
Zimmermann Front sport cross drilled brake rotors
Previous:
      05-18-2017, 10:56 AM   #8
Cloud9blue
Cloud9blue's Avatar
Dinan Camber Plates
Do not get cross drilled rotors if you plan on tracking the car. Get slotted rotors instead.
Appreciate 3
feuer4275.50
Prev8.50
      05-18-2017, 02:22 PM   #9
Prev
Prev's Avatar
Guernsey
9
Dinan Camber Plates
Ah ok, well since this is getting done for trackdays then yes. Will swap to slotted discs.
Previous:
      05-18-2017, 10:17 PM   #10
GATORB8
GATORB8's Avatar
Drives: 2011 335is 6MT
2011 BMW 335is  [9.50]
Harnesses?
https://www.schrothracing.com/products/quickfit#3366
Prev8.50
      05-19-2017, 04:38 AM   #11
Prev
Prev's Avatar
Guernsey
9
At Le Mans I just ran standard seat belt. But that looks like a fantastic option. Thanks for the link.
Previous:
      05-23-2017, 03:09 PM   #12
Prev
Prev's Avatar
Guernsey
9
Thanks for everyone's input. I've placed my order for all the parts.
Got 20days before my next trackday. So hopefully have it all fitted.
Previous:
      05-23-2017, 10:47 PM   #13
feuer
feuer's Avatar
Drives: wife crazy!
Do you have a local track on the island?
      05-24-2017, 06:28 AM   #14
Prev
Prev's Avatar
Guernsey
9
Unfortantly not. The island is 24 square miles so space is at a bit of a premium. But I will be taking part in the local sprint event and hill climb. Used to do it in my Mazdaspeed3, but stopped when I bought my E92.
For trackdays (Am I right in thinking they are called circuit days in the US?) I jump on the ferry to France. Group of four of us going this time, 335, s2000, CRX with a 1.8 integra engine and a Fiat 500 Abarth.
First day we are heading to Fontenay Le Comte http://www.delta-racing.co.uk/events/fontenay-le-comte/ and then the following day we head to http://www.delta-racing.co.uk/events/val-de-vienne/
Previous:
      05-26-2017, 11:17 AM   #15
feuer
feuer's Avatar
Drives: wife crazy!
I used to hillclimb to with my VW. I can tell you that 355i is not very good at that. Track is better suited. I'm Euro transplant in US and they call the events track days here too. Fontenay Le Comte is faster track I think and has good run off areas. Val de Vienne has nice long straight but in some areas the guard rail is too close so be careful.
Prev8.50
      05-28-2017, 05:53 AM   #16
Prev
Prev's Avatar
Guernsey
9
Bit like the Nurburgring then. Been there a few time now. No run off and nice strong crash barriers ready to welcome you at a moments notice.
Two of the lads I'm going with have been and mentioned they are fast tracks. Looking forward to them. You done many European tracks?
Previous:
      05-30-2017, 02:11 PM   #17
davidwarren
davidwarren's Avatar
187
Drives: 328,325, 325, 335, X5, 640 GC
I would go with the CFR radiator over the PPK 2nd radiator.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
feuer4275.50
