TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > DPF Regeneration
      05-15-2017, 01:09 PM   #1
3d Turbo
Ex-Gasser
Drives: 2011 335d ZSP
DPF Regeneration
Hi All.
Is there any way to tell if the car is doing a DPF regeneration?
I recently crossed over the 400 miles threshold since I got my car. On my way to work, the car seemed to be holding gears a little longer, running slightly rough, and mpg dropped down somewhat. This lasted about 10-15 minutes and about 10 miles. Then it went back to normal. No CEL or other warning lights came up at all. Anyone have any insight on this?
Thank You!
      05-15-2017, 01:12 PM   #2
Torqu3
Drives: 2011 335d
Exhaust gas temps are a good tell. Mine reach over 1000F during regen. Get yourself a good OBDII scanner and the Torque app, and install the extended PIDS.
EDIT: http://www.e90post.com/forums/showthread.php?t=1118429 There is a link for the PIDS. Useful for many things.
      05-15-2017, 01:24 PM   #3
3d Turbo
Ex-Gasser
Nice. I already have an OBDII Bluetooth adapter and the Torque Pro app. Is it accurate enough to measure without updated/extended PIDs?
      05-15-2017, 02:12 PM   #4
335stoner
BRR tuned
220
Drives: 335D black
yes it is torque will work..
the car holds gears a lot longer in regen... I first noticed it after I got the XHP tune and could see what gear the car was in... it seems like it tries to maintain about 2000 RPM's before it shifts
      05-15-2017, 02:28 PM   #5
Torqu3
Drives: 2011 335d
Exhaust temp never worked well for me without the updated/extended PIDs. Afterwards they were flawless. Not that they do me much good now that I'm deleted.
      05-15-2017, 03:22 PM   #6
Benskett
Benskett's Avatar
14
Drives: E91 330D LCI
As above really, run Torque and you'll soon see:
Limited EGR 0-40%
600+ degree EGT
The car will operate in vacuum during a regen
Make sure it's over 75 degrees on the coolant too.
      05-15-2017, 03:30 PM   #7
3d Turbo
Ex-Gasser
Limited EGR 0-40%
600+ degree EGT
600 degrees Celsius?
      05-15-2017, 04:13 PM   #8
335stoner
BRR tuned
220
Drives: 335D black
About 1100F
      05-15-2017, 04:57 PM   #9
3d Turbo
Ex-Gasser
Ahh okay.
I read somewhere that more fuel is injected during regeneration to aid in the process and this could contribute to the slight dip in mpg while regeneration is occuring. Can anyone confirm this?
      05-15-2017, 08:42 PM   #10
Persian Whisperjet
Kind of a Big Deal
Drives: 2011 335d
Confirmed!
      05-15-2017, 09:53 PM   #11
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
Prior to my deletes, I recall seeing mileage going from 40 mpg to ~ 33 mpg by resetting the mileage computation in middle of regen.
      05-15-2017, 10:35 PM   #12
3d Turbo
Ex-Gasser
Originally Posted by Persian Whisperjet View Post
Confirmed!
Cool. Thank you. Fairly confident a regeneration is what was happening this morning.
Have my Torque Pro set up to show EGT Bank 1 Sensor 1. Still need to update with the extended PIDs. The below screenshots are this afternoon. The first is at idle, the second is cruising around 50 mph. This is about 3:00 p.m.. My car had been running about 15-20 minutes after sitting for about 5 hours since my morning drive to work.
      05-16-2017, 08:25 AM   #13
Torqu3
Drives: 2011 335d
Yeah, those PIDs are fantastic. It pulls up the 3 temp sensors nice and easy. All 3 of my temp sensors fired off at over 1100F during regen. Normal cruising was in the 500F range, but changed depending on load.
