2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Typical Oil Temp Range
      05-21-2017, 09:30 AM   #1
amw896
amw896's Avatar
583
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
Hey All, does anyone have some input on the typical oil temp range? I monitor mine with a scan tool quite a bit and noticed that I typically sit at 242-246F in normal and hard driving. This is at full warm up and I have a 235i with the aux oil cooler. I guess my question is, does the oil cooler only turn on when you hit really high levels, like 260+? I'm also running the factory recommended 0w-30 bmw oil.
      05-21-2017, 09:54 AM   #2
overcoil
Drives: M235i 6spd
I guess much depends in ambient temp, but when I drive hard which is usually a ten-mile warm-up then approx 15-miles of high-rpm, hard braking but nothing above 130mph, I see around 246F. Using the BMW 5W30 oil.
      05-21-2017, 11:17 AM   #3
amw896
amw896's Avatar
583
Ok cool! Yea, I thought ambient would have a bigger impact I guess. I recently put on a new IC and noticed ambient temps have been more stable but no real difference in oil temps.
      05-21-2017, 08:11 PM   #4
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
244f usually. highest was 250f once during a track day at 100f outside.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
Appreciate 3
      05-21-2017, 08:24 PM   #5
amw896
amw896's Avatar
583
thanks Bryan. I thought there would be a bigger difference when city driving vs pushing it.
      05-22-2017, 01:11 PM   #6
123Britt
Drives: 15 M235i AT
High OIL Temp
I am not sure what is normal - but I have been running a ScanTool OBDLink MX Bluetooth OBD2 Scanner being displayed on Verizon pre-paid phone that I only use for this purpose. I leave the OBDLINK plugged on all the time and read the OIL Temp (among others) often. My oil temps (M235i Stock) stay in a tight range (226-230F) while in Comfort Mode in various outside temps.
Sport Mode & S+ both lower the oil temp & is an indication that oil is running thru the oil cooler.
Just completed a run from Birmingham to Huntsville in 80 deg temps outside in comfort mode (80mph+ for nearly an hour .. Oil Temp display 228-230F.
I run 5W-40 PP EURO & a 50/50 BMW Coolant MIX.
Over 240F seems HIGH. Tracking would be another story.
      05-22-2017, 01:59 PM   #7
amw896
amw896's Avatar
583
wow, yours are quite a bit lower than mine. I'm always in sport+ as well so that makes me even more worried. Maybe I should switch to 40 weight. Does yours burn oil at all? Mine so far has not burned any.
      05-22-2017, 03:11 PM   #8
123Britt
Drives: 15 M235i AT
OCI 5K & never add between changes
No oil consumption -- but I change every 5k.
Heat is a killer and coming from a 07 335i N54 -- I really wanted to understand my normal operating oil temp range - so I got the OBDLink MX -- so now if my oil temps were to rise above 240F -- that would not be normal for my car & style of driving .
A thinner weight oil should run cooler - but I chose the PP EURO 5W-40 because that is what Shell/Pennzoil recommended for my car & with Alabama temps it seems appropriate. It should be interesting to see what my oil temps are in 100F+ with the A/C ON in traffic this summer.
I would be interested to compare oil temps using RL 5W-30 vs PP EURO 5W-40. Being the Ester based RL is superior in handling the heat.
I ran the RL 5W-30 in the N54 with an average of 5deg drop in temps. I do believe that we want temps to be above 220F but below 250F and I would prefer to stay in my normal range 225-230F .
amw896582.50
      05-22-2017, 03:51 PM   #9
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
I have a P3 gauge in my car that I have set to oil temp all the time. Mine will normally run between 244-248 on the street (sometimes drops cooler, but about 80-90% of the time), and on the track actually runs a bit lower (more airflow -- I'm in LA stop and go traffic, so not much air getting to my car on the street).
Normally when I hit my cooldown lap on track, oil almost immediately drops about 10 degrees. The oil cooler in this car is quite robust (with the aux oil cooler). I've only ever seen it hit 250 once, and I was banging into the first gear rev limiter (I was doing drills at a driving school -- dont judge).
Not really sure about people running in the 230s constantly. The car's thermostat does a nice job of keeping the car at optimal temps -- I've done track days with 100+ degrees on track and never had a limp mode problem (heat soak in the charge air is a different story, but oil temps were always fine).
amw896582.50
      05-22-2017, 05:13 PM   #10
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
+1. I have almost the same setup. My temps run pretty much in the same range also. I don't think I've hit over 230F on mine since I've been monitoring it with my scantool. Summer is coming up, so I'll be watching out for changes in temps.
amw896582.50
123Britt287.00
      05-23-2017, 06:16 PM   #11
123Britt
Drives: 15 M235i AT
Make me wonder how a 30wt oil is the right oil
I think 220-240F is an optimal range for our M235i N55 -- and this really makes me wonder how a 0W-30 wt oil which is usually calculated at 212F for viscosity - is appropriate. We need a Poll of avg oil temp at 80f --- not very definitive but would be interesting.
      05-24-2017, 10:17 AM   #12
amw896
amw896's Avatar
583
Did some searching around and it seems 240-250 is pretty normal, some run marginally higher and some a bit lower. This is mostly based on E90 N55 that actually had an oil temp gauge. Looks like once you start breaking the 250's (middle to high) then it's trouble town.
      05-24-2017, 05:53 PM   #13
123Britt
Drives: 15 M235i AT
Schwaben Scan Tool
I will compare my S-Scan tool to my OBDLINK MX this weekend. I am betting all our N55's fall within a range (stock engines) and the variations that we are seeing are based on how and where we are reading the oil temps & or even confusion over coolant temps.
Regardless the oil temps are what I consider high (above 240) where the concern starts and raises an eyebrow as to the oil spec / viscosity and OCI.
amw896582.50
      05-26-2017, 11:32 PM   #14
XutvJet
Drives: 2011 Cayman Base, 2016 M235
240-250 is quite normal in these cars in daily and hard driving. The temps are quite stable once the oil is fully warmed. As for exceeding 250 degrees, I wouldn't worry about it much. Performance oils like those used by BMW, especially euro formulas, will do just fine even living in the 260 range for short durations. Oil tech has improved massively in the past 10 years.
amw896582.50
      05-27-2017, 09:58 AM   #15
aerodavew
Drives: 2014 M235i
How long does it take the oil to warm up in city driving?
      05-27-2017, 11:36 AM   #16
amw896
amw896's Avatar
583
Depends on ambient but I would say at least 10-15 miles.
      06-12-2017, 04:09 PM   #17
amw896
amw896's Avatar
583
Thought I would update since we had a scorcher here today, almost 40D Celsius! I'm mighty impressed with the cooling system on this car. I was at 120 IAT and 245 degree oil temp in traffic, then I got her on the highway, had some space so I started ripping her. The Wagner IC dropped the IATs almost immediately to high 90s, coolant temps went from approx 225 to 175 and oil temps dropped from 246 to 215! They stayed at these temps roughly for the entire highway run, a good 10miles before I had to get off again. I was kind of hoping the temps would stay a bit lower while in city traffic but it is what it is I guess.
      06-12-2017, 10:06 PM   #18
rightrudder
Drives: 2017 BMW M240i
Not sure what the actual oil temps are, but I read somewhere that the less aggressive the driving mode, the higher the temps. So EcoPro will be the hottest, all other things being equal.
      06-13-2017, 07:08 PM   #19
amw896
amw896's Avatar
583
This is true, i drive almost entirely in sport+ so all of my recorded temps are in that mode
      07-01-2017, 02:23 PM   #20
MarcoZandrini
Drives: 2018 M240i
The consensus is the engine reaches its full operating temperature at about 10 miles of continuous driving.
      07-01-2017, 02:42 PM   #21
pikcachu
pikcachu's Avatar
1398
Drives: M235i (F22 Red angel)
Something interesting I realized today is that if you go to the vehicle info - service - measure oil level, if the car is not at operating temp, the start measuring oil will be grayed out
One this advantage is that you need to be in P or N for it to work. So if you are moving you can't check cause it will be grayed out cause it's in D regardless if oil is at operating temp or not
      07-03-2017, 02:06 PM   #22
bryan_G01
bryan_G01's Avatar
1165
[QUOTE=pikcachu;21897031]Something interesting I realized today is that if you go to the vehicle info - service - measure oil level, if the car is not at operating temp, the start measuring oil will be grayed out
/QUOTE]
This is how i found out what operating temp was, using my torque pro app + waiting for it to become available.
www.nybmwcca.org
Current Cars:
2addicts
