05-02-2008, 11:40 AM | #3 |
Rep 288
Drives: Soon 2015 M4
.... have any pics of that car? I want to see the wheels!
05-02-2008, 02:15 PM | #4 |
If You Aint First, You're last !!!
81
Rep 2,509
wicked sick.
08 BMW BSM 335i 6MT (Sports, Premium, NAV, PDC, AS, IPOD, HD Radio, Rear Sunshade, OEM Alarm) Angel iBright V3, Luminics Fog Bulb, Turbo Tuner, K&N Drop in Filter, Dinan Exhaust, Dinan Pedals, Vorsteiner CF Front Lip, and CF Rear Diffuser. Ordered:08/25/07 Started: 09/09/07 Finished: 09/14/07 On Ship: 09/15/07 Arrived: 10/08/07 Delivered: 10/10/07 |
05-03-2008, 01:53 AM | #6 |
Rep 1,436
Drives: E70 X5 M
Wow, that intake sound is wicked!!! Was the install easy or hard? Any hacking (drilling/dremeling) or all bolt-on? Thx!
'13 E70 S63B44A
'17 95B GTS |
05-03-2008, 09:24 AM | #7 |
Rep 1,429
I want to hear the intake under load, it'll sound sooo much meaner.
05-03-2008, 11:48 AM | #9 |
Rep 149
thanks for the kind comments. i'll try to get some vids or sound clips when under load.
some pics as requested. installation details can be seen at this link http://www.m3post.com/forums/showthread.php?t=136722 they are all-bolt ons. no cutting hacking or welding needed. the CAI took around 2 hours, cos the mech needed to figure his way around the new e92m3, remove the original intake before installing this CAI. I was there throughout and didn't seem that difficult. The exhaust was even easier... bolt off, bolt on... cheers ps. sounds much better in real life especially under load at 6k plus revs... |
05-03-2008, 06:11 PM | #11 |
Rep 1,436
Drives: E70 X5 M
Thx for the install info.
'13 E70 S63B44A
'17 95B GTS |
05-03-2008, 11:37 PM | #13 |
Commander-In-Chief
2119
Rep 8,922
Drives: 2023 M2 Coupe, 2020 GLE 450
It looks cool but I'm just not seeing how it is going to be better performing than stock.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
05-04-2008, 02:11 AM | #14 |
Rep 149
in-cabin vid+sound posted on another thread...
http://www.m3post.com/forums/showthread.php?t=139215 cheers |
05-04-2008, 02:16 AM | #15 | |
Rep 149
the comparison chart was between stock and CAI+Exhaust on the dyno. http://www.m3post.com/forums/showthread.php?t=136729 i'm guessing the CAI contributed maybe 2-4hp increase...? cheers |
05-05-2008, 01:51 PM | #16 | |
Rep 149
i had intended to do a dyno after the CAI was installed and before the exhaust, but we were running a little behind and the dyno mech couldn't fit us in at the appropriate time, plus my guy told me i needed some time for the ecu to "get used" to the new intake (and exhaust) before any change could be seen or felt. so the dyno results could be 100% as a result of the exhaust mod and nothing to do with the CAI... sigh... a small point to note is that while you're right in that it's a part-for-part replacement of the OEM parts, the GruppeM main box appears slight smaller than the OEM box, and also designed to sit further away from the engine, and therefore further away from the heat. i'm unsure if CF is a better insulator of heat than the OEM plastic, but if it is, together with the design, could cause cooler air to enter the engine thereby allowing better performance... unfortunate about the dyno, as that would have given us all a better idea of the "usefulness" of this mod... cheers |
