M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > HomeLink
      05-25-2017, 11:33 AM   #1
mike in o.c.
mike in o.c.'s Avatar
96
Drives: 2018 X5 M / 2018 X3 M40i
HomeLink
Does the M2 come with HomeLink (garage door opener)?
      05-25-2017, 11:40 AM   #2
McGary911
McGary911's Avatar
Drives: 2017 LBB M2 DCT
It sure does. A bit of a pain to program, but they all are. Mine's working fine these days (and the other cars work too).
2004 E46 ///M3 SMG Convertible Carbon Blk\Imola
2017 LBB ///M2 DCT
2013 Porsche Boxster S
      05-25-2017, 11:44 AM   #3
atxsk8r
atxsk8r's Avatar
Drives: 2020M2C
Hell yeah a pain to program and screw reading the manual to figure it out. I found a youtube video which made it easier to program and wish i would of done that first, stupid manual
      05-25-2017, 11:44 AM   #4
mike in o.c.
96
Good to hear. Thanks.
      05-25-2017, 01:02 PM   #5
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
For some reason the M2 was WAY easier to program than the older X5. Took literally 2 seconds and one trip up the ladder.
+1 on the video idea.
      05-25-2017, 01:12 PM   #6
oscarin
Drives: M2
In europe,no.
      05-25-2017, 01:50 PM   #7
3Si
3Si's Avatar
217
Drives: 16 M2, 16 Macan S, 08 Elise SC
Way better than Porsche's homelink which interferes with LED lights...
      05-25-2017, 04:55 PM   #8
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
I had no problem programing mine for both the rolling code at home and non-rolling code at work.
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      05-25-2017, 06:57 PM   #9
Zoominrex
Zoominrex's Avatar
51
Drives: F87 MG M2
Got a link to the video you used?
      05-25-2017, 08:45 PM   #10
Zippster
Zippster's Avatar
Drives: 17 BMW M2
I agree, it was a pain it took me a couple of try's. I had to ignore the Blinking LED on the mirror that was telling me it learned and keep holding down the button and then it took.
      05-25-2017, 09:05 PM   #11
salmonbum
salmonbum's Avatar
12
Drives: 2017 M2
Mine was easy. I went to the actual garage door opener and took light cover off. There is a button you push that gives you 30 seconds to auto program. Just get in the car (or just about any car with homelink) and hold the button down until it stops blinking. I have it in 3 of my cars and just did all 3 in 2 minutes, along with 2 other remotes.
      05-25-2017, 09:20 PM   #12
atxsk8r
atxsk8r's Avatar
Drives: 2020M2C
My issue was i needed to do two steps due to my garage door opener version. I was only doing the first step and getting no where with it working, dumb manual
drewF8726.00
Rumbloki176.00
      05-25-2017, 09:56 PM   #13
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
5 weeks in the M2 and I have not been able to program it.
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      05-26-2017, 09:11 AM   #14
UltraMagneticAL
Meh
UltraMagneticAL's Avatar
926
Drives: M3CS & Cayman S
2019 BMW M3 CS  [0.00]
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
once i programmed the m2, it broke the programming in my i8. which was weird. haven't tried programming the i8 again since i just use my automation system to control the garage. i8 has ifttt integration so i can automate my garage to open and close based on it leaving/entering a geofence.
      05-26-2017, 09:26 AM   #15
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Drives: 2016 LBB M2 DCT
Programming it wasn't an issue....I just followed the steps in the owner's manual which went fine.
However, I'm finding that, intermittently, it just doesn't seem to work properly. Maybe 1 in 20 times, the garage door will not open. I'll need to leave it for awhile, or open it manually...and after that Homelink seems to work fine again.
      05-26-2017, 11:00 AM   #16
rich8566
rich8566's Avatar
Drives: M2 + Z-4
Totally cool - how can I set this up?
      05-26-2017, 11:28 AM   #17
UltraMagneticAL
Meh
926
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
i tried looking for the ifttt integration in the m2, but i couldn't find it. plus you'll need a home automation system. i could technically open my garages w/ voice commands too.
      05-15-2019, 01:31 PM   #18
SConn
SConn's Avatar
Drives: 2018 M2
Old post, I know, but I'm experiencing the same problem with Homelink working intermittently. Did you ever get this resolved?
Anyone else have problems with Homelink working sometimes and other times not? Thank ahead of time
      05-15-2019, 02:05 PM   #19
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Wow....blast from the past
After the first few weeks I was able to consistently get it to work. I think it was just user error. Maybe didn't have quite the same range as my previous car, but once I figured out the distance, how long to hold the button down, etc. it was not an issue.
Good luck!
      05-15-2019, 03:33 PM   #20
SConn
SConn's Avatar
Drives: 2018 M2
Good luck!
Thanks for your reply! It was working perfectly the first couple months. Then I started parking it in our shop for a couple months. I just moved it back to the garage and the problems started.
It'll open fine from a good distance, I pull in and then I can't close the door. Then I tried to leave the garage and it wouldn't open the door. I was reading on a Tesla forum about possible interference from led lights, so I tried that theory. I waited for the lights to go off and I was able to open and close the door. Then I tested it again with the lights on and the door opened, but I couldn't close it.
I may just delete the door and reprogram it to see if that takes care of it. Frustrating! Lol!
      05-15-2019, 06:49 PM   #21
particulardude
particulardude's Avatar
Drives: LR4 | L405 SC SWB
Mike
This is interesting. What is rolling/non-rolling? I have a card I have to reach out and swipe for work garage - is this something I can program into HomeLink?
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude
      05-16-2019, 08:47 AM   #22
CTSean
323
Drives: LCI BSM MT M2
Obviously there's detailed explanations online, but the basic idea is a non-rolling code system has one static code that opens and closes the device (gate/door/whatever) which is not very secure. Rolling code system change the code each time.
There no way the homelink could replace a keycard entry. Homelink only works with radio frequency controlled devices.
m2
