M2 Technical Topics > Suspension | Brakes | Chassis > Video: DIY Lowering Spring Install (and front camber plate)
      05-29-2017, 08:46 PM   #1
UltraMagneticAL
Meh
UltraMagneticAL's Avatar
926
Drives: M3CS & Cayman S
2019 BMW M3 CS  [0.00]
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
I've started putting together videos of how to do some mods on the M2, and finally got around to finalizing this spring install video. Thanks to recycledAlva for letting me work on his car and film the project.
Some things to note: I make these videos using regular hand tools, since not everyone has access to an air compressor. I also used the E92 M3 bolt torque specs. To install a camber plate, follow the directions to drop and reinstall the suspension, except replace the top-hat w/ your new camber plate. Use the torque specs recommended by the camber plate manufacturer.
This video is to be used as a guide only. Always consult a reference manual before doing any work on your vehicle. Always secure vehicle w/ jack stands and wheel chocks when working under your vehicle.
Appreciate 8
BAN_M2C4180.00
MR_M2519.00
dj202093.50
D CHOI581.00
BSMF87139.50
Pyrat 21417.50
Mosely593.50
      05-30-2017, 08:13 AM   #2
f87chas
Drives: M2
Thanks so much for the video--exactly what I needed! I just wanted to verify there was nothing unique to doing the job on a M2. Great video--thank you for taking the time to send the link. Be Well
      05-31-2017, 02:23 AM   #3
D CHOI
D CHOI's Avatar
581
Drives: 2017 BMW M2
That beat tho...lol
      08-12-2019, 10:27 PM   #4
cmb570
9
Drives: 2013 bmw 135i
Has anyone kept top hat of front strut installed to vehicle. Just unbolt center strut bolt from top and slowly lower control arm freeing spring with jack. Then insert new lower spring and raise to tighten center strut bolt again with jack ..
      08-12-2019, 11:26 PM   #5
Mosely
Mosely's Avatar
594
Drives: '18 M2 | '20 X5 | '07 E92
Nice work man, wish I had the ability to do a video to go along with the coilover DIY I posted a while back (included all the M2 torque specs in that one). Only thing I might add is the "indexing" of the bushings. Video is super well done though!
IG Photo Gallery:
instagram.com/dr_m2sko/
      08-13-2019, 06:56 AM   #6
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
On the rear, if you remove the bolts at the the other end of the wishbone, you do not have to reindex or mess with your camber.
2018 M2 - Daily Driver/Track Car
Motorcity BMWCCA Member
Instagram | YouTube
      08-13-2019, 12:37 PM   #7
M Fifty
844
Drives: M2 & 330CI
Originally Posted by cmb570 View Post
Has anyone kept top hot of front strut installed. Just unbolt center strut bolt from top and slowly lower control arm freeing spring with jack. Then insert new lower spring and raise to tight center strut bolt again with jack ..
Yes, although I did it when fitting the MPS. Remember to disconnect the roll bar link and headlight height control sensor.
m2
