350d swap.
06-01-2017, 10:17 AM | #1 |
277
Rep 1,575
350d swap.
came across this article. anyone want to attempt this???
http://www.carscoops.com/2015/11/bmw...0d-engine.html |
06-01-2017, 02:10 PM | #3 |
389
Rep 1,623
06-03-2017, 06:30 AM | #6 |
559
Rep 1,502
Drives: F36 435xd
Nice conversion but old news. Read about almost a year ago....
Could be interesting to see how much power could be made from that engine though.....racechip promise approx 470hp with box tuning.....
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
06-03-2017, 08:20 AM | #7 |
Ex-Gasser
31
Rep 68
I feel that at the rate BMW has been going, they're going to end up discovering the most efficient setup is a one turbo per cylinder ratio, with varying turbo sizes.
06-09-2017, 11:45 PM | #8 |
Rep 281
I doubt that.
"This estate BMW started life as an ordinary, fairly-potent 330d, but now it can sprint from 0 to 100km/h (62mph) in just 4.9 seconds and all the way to a limited top speed of 296 kmph/184 mph. Why? Because BBM Motorsport fitted the 3-Series Touring with the tri-turbocharged, 3.0-litre mill found on the M550d. "
SLOW & SMOKEY. My car loses to every Chevy Malibu unless I mash the throttle.
Mods: *ATM 304SS Turbo-back exhaust, w/ ox-cat *ATM stepped intercooler *ATM silicone tubing kits (hot & cold sides) JR 2.8 tune *Whitbread CP3R90 HPFP *AArod EGR racepipe*Execuhitch hidden hitch *Stage 3 transmission tune |
06-10-2017, 08:30 AM | #9 | |
Rep 1,157
06-10-2017, 12:09 PM | #10 | |
Rep 2,210
06-10-2017, 12:24 PM | #11 |
389
Rep 1,623
06-20-2017, 05:45 PM | #13 |
Rep 281
They're at 0-62 in 4.9 seconds with a much heavier car.
Repeat your runs with your car at 4608 lbs wet weight (no fair counting your body weight) , and then we'll be impressed Edit to add: on street tires: "...Z-Performance 19-inch ZP10 rims wrapped in Michelin Pilot Sport tires."
Mods: *ATM 304SS Turbo-back exhaust, w/ ox-cat *ATM stepped intercooler *ATM silicone tubing kits (hot & cold sides) JR 2.8 tune *Whitbread CP3R90 HPFP *AArod EGR racepipe*Execuhitch hidden hitch *Stage 3 transmission tune Last edited by nicklockard; 06-20-2017 at 05:54 PM.. |
06-20-2017, 10:32 PM | #14 |
Rep 2,210
Why does it weigh so much? The f30 wagon weighed under 4000 lbs, they are only up to about 100 lbs more than the d is if you go by advertised numbers.
My run was on street tires. I can't repeat it anyway unless I put in a ton of work in since I don't have full stock exhaust anymore nor a jbd to pair to it Last edited by Hoooper; 06-20-2017 at 10:39 PM.. |
06-21-2017, 07:00 AM | #15 | |
Rep 2,410
https://www.auto-data.net/en/?f=showCar&car_id=20751 1705 kg is less than the weight of the NA version of the 335d. How did they add ~850 lbs with the engine swap?
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
06-21-2017, 10:54 PM | #16 |
Rep 281
Sorry guys, I was wrong--I'd grabbed the wrong weight. I don't know how much heavier the 550d engine is.
Diesel on ..but I still want to see the slips for 0-62 in 4.9 seconds, on street tires. Proof or it's just internet bluster.
06-22-2017, 07:05 AM | #17 |
Rep 2,410
Does a street legal DOT drag radial count? It's a legal "street tire" :-)
06-22-2017, 10:43 PM | #18 | |
Rep 281
No, be legit and use tires equivalent to Michelin Pilot Sports like he does (which are amazing street tires, IMO.)
06-22-2017, 11:33 PM | #19 |
Rep 2,210
Here's one I found in old pictures. I know that it's on jbd and meth with 265/35 r18 continental dw tires based on the carpet on the background. Calculator says 4.17 0-60, I'm sure there are other calculators around which would give some numbers possibly higher and lower but I'm sure none as high as 4.9.
