BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis 2017 540i MSport w/ 7 series wheels
      06-08-2017, 10:03 PM   #1
pkancel
pkancel's Avatar
Drives: BMWs
Finally got everything installed. Not the best pics but when I get time with better lighting will retake.
Here are the specs. These wheels are the BMW OEM 648M off a 2016-17 7 series. By the way, the 7s TPMS matched also and worked so I didnt have to remove mine from my OEM 19s. The wheels are 20X8.5 ET 25 / 20X10 ET 41. Before installing them, I had Son Tran do some accent painting on them to make a little more aggressive and similar to my M4 wheels. So he taped off the center area around the spokes and color matched to the dark grey areas that came from the factory. If you are in So Cal, Son Tran is absolutely the best at repairing damaged wheels. In this case just painting but he did a excellent job. Tires are Nitto Motivo - 245/35-20 fronts and 295/30-20 rear. Yes 295s and Jesse at Americas Tire in Lake Forest was behind the sizing. He assured me the 295s would fit with everything and look proportionate so I purchased them but asked him to also get 275s just in case as a backup. He was right, no rubbing inside nor out even after testing every possible angle to get them to rub. The offset of 41 with 20x10s is just the perfect fit and looks awesome from every angle. I wanted a close to OEM look with something slightly different and thats what I got. I had attempted to buy the 668M wheels but no idea when they will ever be available. Again, sorry about the pics, when I saved to photobucket they automatically downsized for some reason. The only thing different I would do, is 255/35s on the front so I have a little wider front because there is plenty of room.
Mr.blue223.00
      06-08-2017, 10:46 PM   #2
Jdubya
Drives: 2014 550i
Looks awesome. Nice job.
      06-09-2017, 11:39 PM   #3
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Looks good.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      06-10-2017, 12:37 AM   #4
pkancel
pkancel's Avatar
Drives: BMWs
Thanks so much guys
      06-10-2017, 03:21 AM   #5
HawaiiG80Green
538
Drives: 2017 M2
Thanks for the confirmation these wheels will work. Looks great
      06-10-2017, 05:02 AM   #6
Jay R
Jay R's Avatar
21
Drives: g30 540i
Car looks great! When you get a chance post some ass shot pictures of the car to get a better perspective of the 295's
      06-10-2017, 06:39 AM   #7
cr55
Scotland
Drives: G05 X5 30d M Sport
Looks amazing, so much better than 19" oem, if changing I would go this way also, would appreciate some more larger pics 👍🏻
      06-10-2017, 08:16 AM   #8
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
I think it looks good, but those pics are really small.
And I assume you mean ET25 in the front.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      06-10-2017, 12:46 PM   #9
roho3323
The Professor
roho3323's Avatar
Drives: BMW M6, BMW M240i, BMW 750i
Those look great. Nice job!
2010 BMW M6
2007 BMW 335i,2012 Audi S4-retired
2016 BMW 750i M-Sport
2015 BMW M235i-retired, 2022 M240i
      06-12-2017, 09:57 PM   #10
pkancel
pkancel's Avatar
Drives: BMWs
Better pics later this week, traveling now. Just dont know why photobucket downsized them so much.
      06-14-2017, 04:22 AM   #11
Jay R
Jay R's Avatar
21
Drives: g30 540i
Originally Posted by pkancel View Post
Trying these to see if better pics... I can tell already that photobucket automatically downsized these too. Never had this happen before. I tried increasing the size but then they get blurry. Anyone have other ideas so they pics are easier to see or even enlarge when you click on them?
Try taking the pictures with your mobile device
      06-19-2017, 04:26 PM   #12
pkancel
pkancel's Avatar
Drives: BMWs
I did with my phone initially and the most recent with camera, same results, photobucket doing something hadnt happened before.
      06-22-2017, 03:23 AM   #13
Motorboat411
Drives: BMW 535i
Can you share Hi-res close-up of front wheel/fender in which all of the caliper is visible i.e. not covered by wheel spoke? I'm trying to photoshop Brake Decal on it, can't find a pic with entire caliper visible.
Thanks!
      10-24-2017, 01:47 PM   #14
Gmoney El Nene
Gmoney El Nene's Avatar
52
Drives: 2018 540i M
Hottttttt!!!!!!
2018 540xi MSport, Med Blue/Mocha
Exec Pack, Cove Mat, HK, Carplay, Lux Seats
19"664M, Wifi, Driving Assistant
      10-31-2017, 01:29 PM   #15
solomonshv
Drives: 2021 X6
i'm planning to do the same. i found these rims dirt cheap at a car mod shop. they have several sets just laying around. should look nice with the m sport brakes.
      07-21-2019, 01:55 PM   #16
devil84
United Kingdom
116
Drives: G30
Looks great. Do you need to use longer bolts or do you just use the ones supplied on the 5?
      07-21-2019, 10:55 PM   #17
pkancel
pkancel's Avatar
Drives: BMWs
No, fortunately the same ones that were on the car were the same length for those found on the 7 for this wheel. Very easy application all around.
      01-25-2020, 02:14 AM   #18
revup1212
Drives: bmw
I'm looking for these 648s as well. Does that mod shop have anymore sets?
      01-25-2020, 11:48 AM   #19
revup1212
Drives: bmw
I'm wondering if the oem tires that come with these 648s will look to big on 540 g30? Any thoughts?
Front - Pirelli P Zero Run Flat Tires 245/40/20
Rear - Pirelli P Zero Run Flat Tires 275/35/20
5post
