Projector adjustment
06-11-2017, 12:11 PM | #1 |
Rep 112
06-11-2017, 01:14 PM | #2 |
55
Rep 336
Drives: 2010 BMW 335d
Garage List 1984 Dodge Ramcharg ... [0.00]
1988 Ford Bronco 351 [0.00] 2002 BMW e39 540i S ... [0.00] 2010 BMW 335d [0.00] 1997 Husaberg FC600 [0.00] 2010 X5 35d [0.00] 2015 Can-Am Outland ... [0.00] 2004 Ford F350 Supe ... [0.00] 2014 Ford Edge (Com ... [0.00] 2014 John Deere D130 [0.00] 2010 John Deere JS46 [0.00] |
Try checking the linkage from the sensor on the control arm. Linkage can pop off or break from large impacts.
06-11-2017, 02:31 PM | #4 |
55
Rep 336
Located on front suspension arms, not the headlight. These:
06-11-2017, 03:18 PM | #6 |
Rep 97
If you can not adjust the headlight with the normal adjustment screws then I would say your issue is within the headlight. There is a pivot point the projector connects to that dislodges itself if you hit large pot holes or have a very harsh impact. Remove the wheel well cover and removed the cover as you would to swap the headlight bulb. On the top of the projector you can see the pivot point that needs to be clipped back in. If you hit too hard it will need to be glued. I hit an expansion joint at a bridge in DC and it knocked mine off and was able to clip it back in. Stealership will only replace the whole headlight. This is a easy DIY for someone with small hands leaving the headlight on the car.
http://www.e90post.com/forums/showth...eadlight+servo |
06-11-2017, 04:38 PM | #8 |
Kind of a Big Deal
167
Rep 857
Possible silver lining: If both headlights are pointed down, is can be the leveling sensor under the car. if just one headlight, you pretty much have to pull the front bumper and swap out the headlight housing since that little part that broke is not available in repro. I did mine it too all day but I am not speedy in the garage. if you buy the base Hella unit with no bulbs it is approx $630. if you buy the fully loaded unit it is more like $1,300.
06-11-2017, 04:51 PM | #9 |
Kind of a Big Deal
167
Rep 857
06-11-2017, 08:11 PM | #10 |
55
Rep 336
06-11-2017, 11:11 PM | #11 | |
Rep 112
Thank You! Seems like a lot of money. Il have to maybe do it myself or leave it as is. Only passenger side went down. Still works good, it's just pointing down. Maybe I can find a used headlight Il buy it. |
