Anyone running catted or catless DPs in NY & passing emissions?
06-13-2017, 02:00 PM | #1 |
Rep 151
Drives: 2010 e92 335i AWD
Recently picked up e92 335 n54, and mod bug has bitten me. Looking to go for some downpipes but am concerned about passing NY emissions. Couldn't find any *recent* threads on this.
Not looking to be too loud so am considering catted if (a) they are worth it performance wise, and (b) I won't run into inspection issues and have to revert back. Anyone have recent experience here? Do I need a DP fix? And if so, can I use this without having a tune? Thanks! |
06-13-2017, 07:44 PM | #3 |
Rep 151
Thanks. I've been told NY is very strict. Wonder if it's any different than NJ...
06-14-2017, 04:29 PM | #4 |
Rep 2,347
You're allowed one monitor to fail in New York. I'm catless and I've passed every year. You shouldn't have an issue.
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
06-14-2017, 04:30 PM | #5 |
Rep 2,347
Also stay away from catted downpipes the race cats tend to fail at some point.
06-14-2017, 06:12 PM | #6 |
Rep 749
Drives: 335i xDrive
06-14-2017, 06:20 PM | #7 |
Rep 151
What do you guys mean by "one monitor"? And do you have any other mods that are helping you pass?
06-14-2017, 06:41 PM | #8 |
Rep 749
Drives: 335i xDrive
07-20-2017, 02:51 PM | #9 |
Rep 927
Can anyone else confirm this? That you can pass New York's strict inspection with a check engine light on and catless dps !??
07-20-2017, 07:13 PM | #10 |
Rep 2,347
I run a stage 2 tune that surpasses the check engine light. I believe MHD has a toggle to set the car into readiness if you want all monitors in a ready state. You are allowed to have one fail in New York.
SlimE92185.50 |
07-20-2017, 10:05 PM | #11 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
I ran catless and passed NY. As others said, you can still pass if one of your OBD monitors isn't complete but you still can't have any error codes or SES lights. Without a tune you'll get 2 monitors fail as well as 1 error code at least. With a tune you should be able to get down to 1 monitor and 0 error codes.
Additionally you can try using o2 simulators or spacers. Last edited by 3002 tii; 07-24-2017 at 08:44 AM.. |
07-21-2017, 04:16 PM | #12 |
Rep 37
