ZPOST
  TireRack
      05-05-2008, 09:25 AM   #1
Matjo
Drives: Z4 M Coupé
Lowering Question
Hi all,
Just put my BBS LM's on. They are 245/35/19 and 285/30/19. There is no rubbing at all in the back, slight rub in the front at full turn.
Problem is that the car really needs to be lowered with this setup and I'm thinking H&R springs. How will it affect the the front, will it rub much more?
What do you guys think? Help me out
      05-05-2008, 12:31 PM   #2
GP20
95
Drives: Z4M, F80 M3, 991.2 GTS
It depends on your offsets. My RGR's front offset is -32, and with 245 tires I had slightl rubbing issue but it only happened when I turned the steering wheel full lock.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      05-05-2008, 12:40 PM   #3
Matjo
Drives: Z4 M Coupé
I have the same offset et32, GP20. How much have you lowered the car? Did you have any issues before lowering it?
      05-05-2008, 12:49 PM   #4
GP20
95
I had the H&R springs before when I noticed the rubbing issue. It really wasn't a problem during regular driving.
I now have the TCKline coilovers.
2016 BMW M3
2008 BMW Z4M coupe
      05-05-2008, 02:42 PM   #5
Matjo
Drives: Z4 M Coupé
I will order the springs then.. Thank you for helping me out. I will let you know how it worked for me!
      05-05-2008, 11:49 PM   #6
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Have you considered putting in a spacer--say 12mm or so up front?
You have to be 100% behind someone before you can stab them in the back.
David Brent
      05-06-2008, 09:34 AM   #7
Matjo
Drives: Z4 M Coupé
Probably that would fix the rubb issue, but I think the wheel is already a bit outside the fender, it's OK but more would be too much.
zpost
