BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Max boost pressure on stock turbo
      07-14-2017, 10:18 AM   #1
Bmwuk
BMW GTS
Bmwuk's Avatar
52
Drives: BMW M90 GTS
Hi All
Just in process of doing some custom remapping plus installing water meth and wondered what a stock recon turbo from a 3.0d m57n2 engine can safely handle in terms of boost pressure in either bar/p.s.i. I believe they range from 1.2-1.5bar / 17-22 p.s.i but correct me if im wrong?
Thanks
BMW M90 GTS
STAGE 3 -- HYBRID TURBO -- WAGNER FMIC -- PROGRESSIVE METH KIT -- 6HP28 w/uprated TC -- DPF / EGR DELETE -- CUSTOM CAT BACK STAINLESS TWIN EXIT EXHAUST WITH REMUS M3 CF TIPS -- M135i FRONT 4 POTS -- 19" BBS CSLs -- RAPTOR XENON HEADLIGHTS -- CIC iDRIVE -- COMBOX -- LEMON DAKOTA INTERIOR --
      07-14-2017, 12:07 PM   #2
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
Drives: Deezul
Stock PSI is 26, and increased I believe is around 35 to 38 or so.
Deleted, ATM I/C and tuned by B.R.R.
      07-14-2017, 01:52 PM   #3
Bmwuk
BMW GTS
Bmwuk's Avatar
52
Drives: BMW M90 GTS
Thanks for info... wow that a lot more than i expected... anybody remapped to that level on here? Figures in bhp?
      07-14-2017, 03:54 PM   #4
Hoooper
Drives: 335D
Check out the threads on BPC and JRTuning. Both of them have "maxed out" stock turbo tunes.
      07-14-2017, 05:07 PM   #5
Miko226
Miko226's Avatar
Drives: 11' 335d
Tons of threads on here but like he said stock is around 26psi and depending on the tune / mods it varies
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD
      07-15-2017, 01:33 PM   #6
Torqu3
Drives: 2011 335d
JR 2.8 is "maxed out" for stock turbos, and I was pushing right at 37psi at the drag strip last night.
      07-15-2017, 07:58 PM   #7
Mrdeezy
Drives: 335d m-sport
Gosh mine hits 40 sometimes with jr 2.8 ��
      07-15-2017, 08:12 PM   #8
335dsleeper
389
Drives: 09' 335d 10'35D
With my EWG, I could make 42-44psi on stock turbos. The problem is the stock turbos are way out of their efficiency range and excessive EMPs. Emps were well above the max recorded value of 58.xx psi. I believe 37-38psi has been proven optimum with the stock turbos.
      08-27-2019, 09:16 AM   #9
Goboro100
Goboro100's Avatar
Greece
11
Drives: 335d
38psi the car will make plenty of power. And 45psi or more can blow end tanks off the stock intercooler.... spike 40 hold 38psi is perfect ����
      08-28-2019, 12:34 PM   #10
ranthum
Drives: Looking to Buy
In my opinion about 35 psi at the intake manifold is optimal for stock turbos. More boost means more heat which means less dense air. Also, to get 35 psi at the intake, pre intercooler boost will be higher.
      08-28-2019, 02:46 PM   #11
robnitro
Drives: x5 35d e70 2011
Yes and to make more boost the exhaust pressure will be higher, limited by the flow of the stock wheels.
There's also a point where too much emp can cause exhaust valves to stay open (acting like egr, forcing exhaust gasses back into cylinders)
