How to drain DEF tanks and fill with distilled water
07-17-2017, 03:45 PM | #1 |
Rep 40
So I have tried searching but am having a hard time finding the right info. I'm about ready to dive into the DPF/SCR deletes and install the ATM downpipe/exhaust/intercooler/intake. I already have the EGR block off installed. I would like to drain the DEF tanks and fill them with distilled water so if the next owner needs to return it to OEM they can. Is there a DIY for this process somewhere?
07-17-2017, 03:50 PM | #2 |
Rep 1,157
To drain: http://www.e90post.com/forums/showth...1089933&page=3
If you're going to refill them to prevent crystallization, you'll have to flush them out thoroughly with distilled water, and then dump in more distilled water to store. Otherwise you're wasting your time. |
07-17-2017, 04:21 PM | #3 |
Rep 153
so i was going to say water is a horrible idea...but i see you are located in Navada so probably wont freeze, but i would still think you would want something like anti-freeze mixed with water or wiper fluid that would resist freezing for w.e. reason you are in a cold area.
07-17-2017, 04:34 PM | #4 | |
Rep 1,157
07-17-2017, 05:40 PM | #5 |
Rep 40
Thanks for those links- that is what I was looking for. But it looks like to really do a good job of draining the urea I would need the special BMW pump apparatus or the electrical equipment/knowledge to activate the urea pump to flush the water thru. Maybe it's not worth it? If I just leave the system full of urea will it crystallize inside the tank over time?
07-18-2017, 07:49 AM | #6 |
Rep 3,557
Nevada is a pretty cold place in the winter at least at higher altitudes. Warm exhaust won't be a factor when parked overnight either. I think a little antifreeze mixed in would be prudent other than completely draining (how does one know if system is really purged?).
07-18-2017, 08:34 AM | #7 |
Rep 432
There are two drain tubes on the driver side of the tanks that make draining them quite easy if you have some patience. I used a Mityvac extractor to speed up the process significantly, then added some water to both tanks, drove around trying to slosh it as much as possible then drained them again.
As I live in Canada, I put a few gallons of low temp washer fluid in there and called it good. If you want you could drive around pre-deletes with the SCR metering valve exposed to atmosphere and it will pump some of the water/fluid out for you. You will get some SCR codes which can be cleared when you do the deletes anyway. If you leave the DEF fluid in there, it will definitely crystallize over time. If you're doing the deletes and removing the tank, does it matter? That's up to you. |
07-18-2017, 11:16 AM | #8 |
Kind of a Big Deal
167
Rep 857
07-18-2017, 11:42 AM | #9 |
Rep 40
Thanks guys. I will just do that same thing- drain the 2 tanks via gravity and then fill them partially up with some windshield washer fluid. I am thinking of doing this about a week before I do the deletes- I have a 50-mile commute each way so I will put on about 500 miles this way. Hopefully the SCR metering unit will pump a little of the washer fluid through the pump and tubing so it doesn't crystallize in there. My goal is to leave the DEF tanks in place, partially filled with windshield washer fluid, so that someday when I eventually sell the car the next owner could return it to stock if they wanted. I'm sure that is unlikely, but it wouldn't take much extra effort to drain the tanks and fill partially with WW fluid.
07-18-2017, 11:16 PM | #11 |
Rep 1,157
07-19-2017, 09:12 AM | #12 |
Rep 153
alcohol is better than DEF or Water...biggest issue with water would be pure water in any hoses, or small confined spaces where freezing would cause water to expand and wreck those components. i would say if you want to keep it 100 empty, drain DEF, Flush with water to purge out any residual DEF so no crystals, and then run rubbing alcohol (prob cheapest) through the DEF tank to purge out water and ensure it is bone dry.
Torqu3 i didnt forget about your pictures |
07-19-2017, 11:22 AM | #13 |
Rep 2,410
Since DEF freezes around +12F and has an expansion ratio similar to H2O (~7% vs ~9%), and a lot of us live in areas that get substantially colder than 12F ... I would expect the tanks/lines are designed to handle freezing fluid. I know I've had completely frozen DEF in my system before as I've parked overnight outside in -20F temps many times and didn't have any rupturing/breaking of tank/lines. Would be interested to hear if people have had problems with ruptures due to freezing/expansion.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
07-19-2017, 01:19 PM | #14 |
Rep 803
Forgive me if I missed it, but what's the problem with keeping the tanks empty?
(Of course after a flush with water to get out any def residue) 6.1 gallons of water total @ 8.34lb/gal is 50 lbs weight saved. |
07-19-2017, 07:27 PM | #15 |
Jumping Jack Flash
321
Rep 1,692
Drives: 2021 X3 M40i
Attached please find the service instruction from a few years back.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
07-19-2017, 08:22 PM | #16 |
Rep 432
I was referring to the SCR converter in the exhaust. I don't think it would be a good idea to shoot highly flammable liquid into there if you want it to retain its function.
11-30-2017, 03:44 PM | #20 | |
Rep 5
Any information would be appreciated, but best if there is a video and link to partd buy. Thanks |
12-01-2017, 12:18 PM | #21 |
357
Rep 1,723
No shit eh? lol
'09 335D
