too much smoke
07-21-2017, 07:02 AM | #1 |
Rep 27
too much smoke
My 335d has been tuned for a couple months now and I've realized the amount of black smoke is way more than normal. OBD reports a max boost of around 29-30lbs. I get smoke anytime over 2/3 throttle, and a large continuous cloud at WOT.
The car: -2011 335d, 120k miles. -BPC stage II, stainless downpipe+exhaust, forge boost hose. Notes so far: -swapped the pairs of pressure converters and switchover valves, no change -inspected turbo-intercooler-intake connections, all appear fine. -No codes either through carly, or at the dealer -replaced a lot (but not all) vacuum lines, and tested actuators. (sound fine) What should I do next? There is evidence of CBU looking down the throttle body. Could that be enough to restrict airflow this much?
Vermillion Red 2012 x5d: JR stage II
Deep Sea Blue 2011 335d sport:Stage II+ (BPC), ATM intake/downpipe (FOR SALE) |
07-21-2017, 08:06 AM | #3 |
Rep 3,557
Look for evidence of boost leak. I see that you have installed a Forge hose. Double check that the connections to intercooler are correct. Also, check further downstream at charge pipe to throttle body as there is an o-ring there. I had a bad cloud thing similar when inlet to intercooler red hose popped off and I got a limp mode. I installed new green o-ring and insured full insertion of hose into intercooler and problem disappeared. Good Luck.
07-21-2017, 09:18 AM | #5 |
Rep 27
I'd agree it sounds like a boost leak.
looks like i'll replace items 2,3,13,14 in the diagram? might as well do them all while i have it apart right? edit:new air filter as of a few weeks ago, no change
07-21-2017, 11:23 AM | #6 |
Rep 1,157
That's exactly where I would start since it's the cheapest and easiest fix. Your peak boost numbers are too low so I'd put my money on a boost leak.
07-27-2017, 06:44 AM | #7 |
Rep 27
Got everything apart last night. Replaced both gaskets on the charge air pipe, and the one on the intercooler side of the boost hose. It does not appear I have gasket #2 on my car, is that normal with the forge boost pipe? Anyone have a picture of what that gasket is supposed to go to?
One of the connections (picture) is all beat up, I cleaned up a couple rough edges, but it seems to be all functional still. Didn't seem to notice a difference this morning, but i'll wait for more data to confirm.
07-27-2017, 07:18 AM | #8 |
Rep 1,288
Just as an observer on here it seems like people have more trouble with the forge boost pipe than benefits.
On mine I'm using the upgraded OE pipe with yozh's tip of doubling up the seals where it mates to the turbo. Working well with no issues. But it did take some muscle and persistence installing. |
07-27-2017, 12:37 PM | #9 | |
Rep 1,442
07-27-2017, 12:52 PM | #10 |
Rep 2,210
I don't know about a beefed up o ring but the clamps should be replaced with t bolt clamps.
Chief Orman671.00 |
08-04-2017, 06:22 AM | #11 |
Rep 27
agreed to the T bolt clamps. one of the hose clamps didnt even go back on quite right.
Is that a 3" pipe I need to buy for?
08-04-2017, 03:57 PM | #12 |
Rep 3,557
Sorry, Chief. I just now came back to this thread. I didn't mean for you to be left hanging. Hooper chimed in better than I could have anyway. My memory was that the Forge uses the same OEM seals we already have but that it has a much better fitting on the top end to connect the hose up with.
Chief Orman671.00 |
08-04-2017, 06:02 PM | #13 | |
Rep 2,210
I think these are what I used on the hose HPS 76mm - 84mm Stainless Steel T-Bolt Clamp for 2-3/4" Hose |
Chief Orman671.00 |
08-05-2017, 09:01 AM | #16 |
Rep 27
exactly the ones I was looking at:
https://www.amazon.com/HPS-SSTC-76-8.../dp/B0058W7X0A anything to avoid one extra round of disassembly well i'll update when two of these go on...
Chief Orman671.00 |
08-07-2017, 02:04 AM | #18 |
Rep 2,615
Boost leaks could also come on the output side of the intercooler, ASV mating areas to boost hose and to EGR or race pipe and same to manifold. Also swirl flaps or block off plates. Check all. For the vacuum system, you need to assure the whole system is tight.
Chief Orman671.00 |
08-16-2017, 01:21 PM | #19 |
Rep 27
Seems better with new clamps in, but no data yet. I should point out these are probably one size too large. Cranking them all the way tight is still loose enough to move them (barely) by hand. Trying these soon:
http://a.co/hxxTBb4
08-17-2017, 07:53 AM | #21 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
Just to actually give a little help, there are boost leak testers out there. Where you pressurize the intake tract and check for leakdown. I've used them on other cars, boost leaks can be hard to find. http://turboboostleaktesters.com/. I also recommend a spray bottle with soapy water to spray all the fittings and look for bubbles. This method is pretty full proof. Also be careful when you pressurize the system to say 30psi, there is a lot of force contained in the fittings if they blow. If its a bad leak you'll be able to hear it.
335stoner220.00 |
