TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Injector activation short codes and low resistance readings
      07-21-2017, 08:49 AM   #1
335djesse
Drives: 2009 BMW 335D
Hello folks,
So I'm having some issues with my D. It started with an intermittent hiccupping and limp mode caused by a 4bc4 code for injector 1 activation (short from high to low). I replaced the #1 injector and the car ran good for about 2 days and then started hiccupping again. I pulled the codes again and noticed that I now had activation codes coming up on almost all of the injectors intermittently except for the new one I had installed.
So I pulled the intake and took resistance readings of all the injectors. The brand new injector reads 180K ohms like it should but all of the other 5 are much lower. And when taking the resistance reading the ohms climb very very slowly on my meter until they max out. The new injector is 180K ohms instantly. The max ohm readings on the other range from 50k ohms to 160k ohms.
Looking like I'm going to have to buy 5 new injectors for this thing but I find it hard to believe that all 6 of my injectors failed at once. Is there anything known to go bad on these cars that can cause 6 injectors to fail? The car has just over 200k kms on it currently.
thanks guys
      07-21-2017, 01:08 PM   #2
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
When I pulled my injectors to do Carbon Cleaning and had them tested, 2 failed the resistance testing as well around 100k miles....but not all... I would see if you can get them tested... check out my post about how to get them tested and where to get new ones
http://www.e90post.com/forums/showpo...8&postcount=12
      07-21-2017, 03:03 PM   #3
torqueisking
44
Drives: 335D Sport
Not sure how you're testing them but I suggest three resistance measurements per injector.
1) Pin 1 to Pin 2
2) Pin 1 to ground (metal casing of injector)
3) Pin 2 to ground (metal casing of injector)
I had an injector fail with almost a dead short from one of the pins (can't remember which one) to ground due to corrosion. The DDE current protection saved the injector drivers by shutting down the engine.
      07-21-2017, 03:48 PM   #4
robnitro
Drives: x5 35d e70 2011
Yep on my x5 5 and 6 got corroded due to the crap tastic plastic that cracks.
To ground from either pin should be infinite or whatever highest ohms you can read .
My bad ones had 1000 ohm to ground and 200 to ground!
      01-29-2021, 05:06 AM   #5
howquick
Drives: 2007 BMW X5 E70
Same issue
Originally Posted by 335djesse View Post
Hello folks,
thanks guys
Sorry to drag up an old thread....did you get this sorted? I’m having a similar issue with one injector. #5.
      01-02-2024, 01:19 PM   #6
semper
Drives: E92
2006 E92 335i  [0.00]
Hi, man did you solved your problem ?
      01-13-2024, 05:39 PM   #7
335dlci
277
Drives: 335d
Dde
