Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > RWD Staggered vs Square
      08-02-2017, 12:56 PM   #1
hybrid90
hybrid90's Avatar
246
Drives: 2021 X3 M40i
2021 BMW X3 M40i  [10.00]
I know this subject has been covered numerous times, but I've read about two dozen threads and most only deal with Xi models and the rest are vague, so I'll post here and see if I can get the answers I'm looking for.
I'm finding myself in a unique position. currently, on my E90 LCI 335i w/Sport Pkg, Premium Pkg & the BMW Power Kit, I am running a staggered set of 230 wheels (19x8 et37 front w/10mm spacer & 19x9 et39 w/5mm spacer). My suspension is the Eibach Pro Kit w/Koni STR.T shocks. I'm currently on RFT's, but I just got a pair of PSS rears (255/30-19) but haven't installed them yet.
At this time, I just acquired another set of staggered 230 rims and the thought occurred to me that I could take the rears from the new set and run a square setup (19x9 et39 w/255/30-19 all around).
So, here are my questions:
1. I know that this would help eliminate the understeer and possibly induce oversteer, but is there a downside to this setup aside from also possibly introducing tramlining? I drive on the freeways and rough roads often so this could be a factor.
2. IT's said that this setup is better for handling (I'd rather have the handling since I also drive a lot of canyon & mountain roads). Is this true and is there a tradeoff somewhere because I've also read that I would also lose turn in and steering response?
3. I plan on continuing to run the spacer in the rear (unless it starts to rub the fender since the PSS tires are a bit more meaty), and will run a spacer up front if needed to push the tires out more flush, but is there any clearance issues that I need to know about?
4. In general, would I be better off staying w/staggered setup or changing it up?
I'm hoping to hear from people that have tried both and have honest A & B comparisions, but anyone who has some knowledge/experience on this, please chime in.
Thanks!!!
      08-02-2017, 01:18 PM   #2
YoungBlood
LongDongSilver
274
Drives: e90 335i
255 is not wide enough to tramline much, tire choice has more impact on that in my experience. I think that would be a good setup, and allow you to rotate tires. And if you've ever autocross, you'd find that the small front tire size is a massive issue, making you have to drive the car very precise, with the wider front tires, you can hamfist it a bit more, and keep your line without understeering.
N54 E90 6AT: 3" Pipes that go down, Thing that cools the inter, PE Mod, DCI, ST XTA, Whiteline bushings, Aodhan, and lotsa corn-juice
      08-02-2017, 01:21 PM   #3
hybrid90
hybrid90's Avatar
246
I've heard that the PSS tires are pretty stable, so I'm hoping that's the case.
      08-02-2017, 02:17 PM   #4
FCobra94
Guest
n/a
Drives:
You already have the parts to make this happen...try it and see for yourself.
      08-02-2017, 02:19 PM   #5
hybrid90
hybrid90's Avatar
246
Originally Posted by FCobra94 View Post
You already have the parts to make this happen...try it and see.
I only have one pair of PSS 255/30-19's. And I didn't think that mixing the RFT's with the PSS's was a good idea.
But I am prob going to give it a go. At least I'll get some knowledge and experience out of it. But I was hoping to get as much info as I could before I spend $400 on another pair of 255's since I already have the staggered set of PSS's.
