Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Slipped drive belt catastrophic damage!
      08-07-2017, 02:28 PM   #1
Mike @ SSR Performance
Mike @ SSR Performance's Avatar
39
Drives: E92 335i, F30 328i
Unhappy Slipped drive belt catastrophic damage!
We have all heard horror stories about belts slipping and getting sucked into the the N54 motors, which can cause SERIOUS damage to the timing chain. But how seriously do you all take it?
Well we hope to enlighten you, and to make you aware that this is a serious issue that should not be neglected.
We have seen this happen numerous times and want to share with you all!
Sometimes we get customers who neglect a leaking oil filter housing gasket, oil cooler gasket, or worn down belt tensioner.
All three of the things we have listed above may potentially cause your belt to slip off the pulleys, causing it to get sucked up behind the crankshaft pulley. Which may damage your engine.
Oil dripping onto your belt will cause the belt to slip under load or even start up. With this happening, the belt will have the possibility of slipping aside.
With a weak tensioner, your belt may start jumping around. Not applying enough tension to your belt and may also cause your belt to slip.
We will share this customers experience with you all, to hope that you may take it into consideration when you see oil leaking onto your belt.
This E92 335i customer has 113,483 miles on his car. The cause of this belt from slipping was due to the belt tensioner. It is suggested to inspect your belt tensioner from time to time.
We will inspect the car further to see if there are any damages to the crank, crank seal area, and drop the engine oil pan to inspect the timing chain for any damages
      08-07-2017, 02:52 PM   #2
FCobra94
Guest
n/a
Drives:
Leaking OFHG/OCG/VC, tensioner, motor mounts, power steering pulley, sub frame contact, etc. can all cause this...to all the n00bs out there, welcome to the wonderful world of N54 ownership!!
      08-07-2017, 02:54 PM   #3
Delta0311
7478
Drives: 2011 BMW 335xi E92 2016 228xi
Hit 70k on my 335 and replaced my pullies and belt last week. Not taking any chances.
BQ Tuning113.50
      08-08-2017, 02:06 AM   #4
nikitino25
nikitino25's Avatar
Drives: '07 E92 335i
What are you looking for when you inspect the tensioner?
      08-08-2017, 04:46 AM   #5
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
Inspect the power steering pulley for damage , it sits so low that it hits the subframe and eventually breaks the belt, red neck solution is to grind the subframe little bit to make clearance, I heard there's revised subframe out there also,
      08-08-2017, 07:02 AM   #6
arhoads335i
Drives: 2015 435i grand coupe xdrive
2008 BMW 128I  [0.00]
Oh we love the N54! I addressed my OFHG the day I bought it, then put 335is mounts in. I havn't looked at the tensioner, is it like other cars where it will make a squeak if its humid out when its going bad?
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current)
2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD)
08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD)
      08-08-2017, 08:01 AM   #7
AlpineBoost
AlpineBoost's Avatar
3928
Drives: '23 Civic Type R
^ Same here, replaced OFHG and upgraded to is mounts. I plan on replacing the pulleys and belt in about 2,000 miles at 100k.
      08-08-2017, 03:00 PM   #8
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
Replaced belts and pulleys a few months ago.
Cheap insurance.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
      08-09-2017, 01:43 AM   #9
m3rxn
Drives: boosted Inline 6's
Thanks bro for heads up!
15 F82 M4,YMB-6MT
17 G30 540i,AW-8spd ZF
24 G82 M4C x-drive, DY-Dakar Yellow ind-8spd ZF
      08-09-2017, 06:51 AM   #10
tylerboland01
tylerboland01's Avatar
53
Drives: 08 335i
I'm about too motor mounts and front control arms, guess I'll do the belt and pulleys while I'm in there.
      08-09-2017, 04:57 PM   #11
twinship
Booosted
twinship's Avatar
44
Drives: 2008 335i
2008 335i  [0.00]
Has it been confirmed that the IS motor mounts are the fix for the pulley contacting the subframe?
Has anyone measured the IS mounts and the non-IS mounts, or photographed them side by side?
2008 BMW 335i//Jet Black on Black Dakota Leather//Steptronic, Sport Package, Premium Package, Logic7 Sound, Aluminum Trim, iPOD & USB, Cobb S1+ Sport, ER FMIC, ER CP, K&N Filter, H&R Sport Springs, Koni Yellows, ECS Tuning spacers (F-10mm/R-15mm), Akebono pads, OEM Rear Aero Spoiler, OEM Sport Diffusor, Cyba 3.8" Tips, OEM Aluminum Pedals, M-tech Steering Wheel, Clear Reflectors
      08-09-2017, 05:11 PM   #12
nikitino25
nikitino25's Avatar
Or the 034 Motorsport mounts for that matter?
https://www.ecstuning.com/b-034motor...SABEgJEBfD_BwE
      08-10-2017, 11:36 AM   #13
mxchris727
mxchris727's Avatar
Drives: '03 M5, '06 325i, '12 M3
Has anyone made a notch in the sub frame where the pulley hits? That would solve the problem once and for all.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
      08-13-2017, 11:49 PM   #14
39
Just an update on this thread! This customers engine was destroyed from the belt. After this post, we had attempted to remove the belt that got inside the crank seal. About 2 feet of belt came out and then it was jammed in there. We had removed the crank seal to save the time of dropping the oil pan. After inspecting it, the belt had jammed itself inside the timing chain and without a doubt, cause timing to be off. This customer had drove about 5 miles after the belt ripped.
As for the power steering pulley, this is also another common issue. Usually, is caused by weak motor mounts. Over time, the motor mounts start to stretch and weaken the polyurethane inside. Which will allow the engine to move much more and at the same time, have the engine sit lower.
The best way to inspect your tensioner is to turn on the engine and take a look at it's movement. Tensioners usually only move about 5-10mm. Anything more than that is considered excessive and should be considered replacing. As under load, it will have much more movement
      08-14-2017, 09:52 AM   #15
Chris@VargasTurboTech
1933
Drives: All Things TurboCharged
Good post! Significant concern and easy to check for! Blow it up from too much power, not from stupid tensioner issues!!!!
Chris
      08-17-2017, 10:01 AM   #16
39
Chris
Great additional information that passed our minds. Higher power does also add to this concern. As the increased speed of crankshaft revolution does also cause belts to slip!
