Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Dyno procedures?
      09-19-2017, 01:08 PM   #1
ChiDiddy
50
ChiDiddy's Avatar
19
Drives: pop smoke
Dyno procedures?
About to dyno, are there any special instructions? Ie. Turning off DTC , etc
      09-19-2017, 01:48 PM   #2
Torqu3
Drives: 2011 335d
"Typically most shops have to pull a tach signal from the injector or use an OBD adapter or an optical reader. When you have the car on the dyno you will need to turn off the traction control(Long press). Put it in manual and run through the gears slowly you will probably feel at some point when the traction control disengages completely. You cannot go quickly from first gear to 2nd gear to 3rd to 4th. Switch between gears slowly. Do the Dyno in 5th gear. Most shops don't have a brake big enough to use 4th gear accurately."
I asked this same questions a few months ago and this is the answer I got. Report back with your numbers, and take note of what brand of dyno it is.
      09-20-2017, 06:47 AM   #3
2011335d
Drives: 335d
tach signal can be found in the DDE case. If memory is correct its a brown wire with silver tag. wire color might be wrong but look for a wire with a silver tag.
      09-20-2017, 01:29 PM   #4
ChiDiddy
50
ChiDiddy's Avatar
19
Drives: pop smoke
Thx guys!
