Loss of power steering, battery icon, and smell of something burning!
09-27-2017, 05:39 PM | #1 |
Rep 64
My 335d has 55K miles.
All has been normal. Stopped into a supermarket, get a battery icon on the dash, loss of powering steering, and what smells like burning tires. Car is inside my garage now. What I notice is that the serpentine belt doesn't appear to be moving. It's in tact (belt was replaced at 35K miles), but looks like it's struggling to move, as noticed by staring at one of the upper pulleys connected to the serpentine belt. What the hell is going on? |
09-27-2017, 05:50 PM | #2 |
Rep 217
It's your crankshaft pulley. Pretty common failure on these cars. Search this forum and you'll find plenty to read up on. It isn't a terrible job to fix, but you'll need a tow either way. I wouldn't drive the car.
09-27-2017, 06:07 PM | #5 |
Rep 64
ECS tuning has a kit with everything. https://www.ecstuning.com/b-assemble...11238511371kt/
Do I need this kit, or do I just need the crankshaft pulley? |
09-27-2017, 06:07 PM | #6 |
Rep 112
Here's the diy and you also got the parts needed for the job.
http://www.e90post.com/forums/showth...monic+balancer |
09-27-2017, 07:36 PM | #7 | |
Rep 112
09-27-2017, 08:29 PM | #8 |
Rep 64
335dsl thanks for the help so far. I went ahead and purchased the full kit from ECS, and will just replace that crap as part of preventative maintenance.
Have you done this job before? I'm trying to read the DIY from Mik325tds, but i'm struggling to follow his additional tips regarding the fan cowl removal. |
09-28-2017, 08:18 AM | #10 | |
Rep 202
I predict that the other thing that will give you trouble is the A/C belt installation. I made multiple attempts using a stretch belt tool and just could not get the 824mm to go on. I gave up and just re-installed the old 830mm belt. If you manage to get the 824mm belt on, let us know how you did it -- I'm not the only one here that had trouble with it. |
09-28-2017, 08:56 AM | #11 | |
Rep 441
This is leading me down a path to say that calendar age might be significant determinant .... Maybe the rubber breaks down and is just inevitable regardless of miles or HP/TQ numbers.....It could also play into the climate....the rubber would break down less in colder climates, right? ...Dr Thermodynamics .... what do you think? Last edited by OmahaDZL; 09-28-2017 at 09:34 AM.. |
09-28-2017, 10:05 AM | #12 | |
Rep 64
Upon closer inspection this morning, I can confirm that the crankshaft pulley has taken a shit. There are rubber chunks sitting on the pulley. |
09-28-2017, 10:06 AM | #13 | |
Rep 64
I bought the new AC belt from ECS, and I already have the Lisle belt tool. I'll let you know if I have any issues. |
09-30-2017, 07:11 PM | #16 | |
Rep 3,557
Not a Dr as in not a PhD but versed specifically in heat transfer. My take is abuse of a part is the the the time integral of heat and torsional load. That means it's a combo of the loading and heat over the service life. Omaha knows this failure heee is right in my backyard mileage wise. I just crossed over 58,000. I still see this on the minus 1 sigma side of the failure population. PR is another 51,000 mile failure. He was tuned (where the heck has he been by the way). I've been running tuned for 26,000 miles and 3 years. Time will tell and you guys will hear if/when my number comes up. |
09-30-2017, 07:42 PM | #17 | |
Sleepy
75
Rep 367
09-30-2017, 11:13 PM | #18 |
Rep 722
Harmonic Balancer dead.
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
10-02-2017, 09:43 AM | #19 | |
Rep 202
I don't know enough about these things to opine, but figured you and others here are knowledgeable enough to offer a more informed opinion. Thoughts? |
Torqu3320.50 |
10-02-2017, 10:33 AM | #20 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
AS to why these particular harmonic balancers fail so early is a matter of speculation. I'm also seeing failures becoming increasingly common on the S63's as well.
The major factors that seem to determine wear on these from what I can tell, are age, heat, oxygen and ozone exposure which degrades the rubber. Of course also the amount of time spent at idle as my understanding the M57 places its greatest harmonic load on the balancer at idle. But Ozone exposure really seems to be a major factor in the rubbers degradation. Plus heck these cars are all old now. No one expects tires to last more than 5 years when exposed to the environment, its probably not unexpected that these are failing as the youngest cars are approaching 7 years old. I'm at 61K miles and mine is visibly cracked. I plan to replace my HB as soon as the weather cools down here. Last edited by Thecastle; 10-02-2017 at 10:44 AM.. |
10-02-2017, 07:13 PM | #22 |
Rep 1,157
My October 2009 build date, MY 2010 335d spent its life in downtown Houston. I bought it at 70,771, drove it 150 miles home, and it failed. Right at 71k. So, be prepared. The day is coming, but the fluidampr is coming too.
