Coolant Hoses replacement?
10-03-2017, 04:41 PM | #1 |
Rep 50
Hi Bimmers~
My car is a 2012 e92 335i with n55. I replaced the coolant reservoir and radiator a while ago, but it showed low coolant again yesterday, The dealer said the there are two coolant hoses need to be replaced, one is between engine block to the water pump, and the other one is the water pump to the thermostat. They want to charge $1500 for these two plastic hoses, which is insanely expensive. How much do you guys usually pay for this type of repair?? |
10-08-2017, 07:32 AM | #3 |
Gateropode
329
Rep 2,848
The hose between the block and the pump is very expensive and annoying to replace, hence the steep price. However, it is not a known weak point and most people run that hose for the entire lifetime of the car with no problems.
10-10-2017, 09:59 PM | #4 | |
Rep 50
The hoses weren't leaking, not the car still drives fine, but they recommended me to replace it. |
10-13-2017, 12:31 AM | #5 |
Rep 3,131
Drives: 2011 335i e92 DCT
My car is needing a top up weekly at the moment i cant find the coolant leak, its super annoying.
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
Tags |
coolant hoses n55 335i e92 |
