M2 Technical Topics > Suspension | Brakes | Chassis > M2 on H&R Springs and Spacers
      10-06-2017, 07:29 AM   #1
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
What do you recommend? I am thinking on going 10mm all around (or 12mm)with car lowered on H&R srpings?
Any issues for tracking/rubbing?
Post pictures if possible.
Thanks for your help.
      10-12-2017, 05:41 PM   #2
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Look what I got in the mail today...
      10-13-2017, 11:02 AM   #3
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
I have the H&R springs and 10mm spacers and I rubbed at all four corners till I got an alignment and then now the only time I rub is on some dips on the front right wheel. To guarantee that you won't rub you should get front camber plates
Benzima1324.00
      10-13-2017, 11:33 AM   #4
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Do you think it would rub without the 10mm spacers?
      10-13-2017, 11:38 AM   #5
twin fed
Doc Brown
twin fed's Avatar
1176
No, I don't think it will. you could always get 5mm spacers if you want to be 100% sure. But there are others that run 15mm spacers and H&R springs and have no issues. Each car is slightly different.
      10-13-2017, 11:48 AM   #6
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Thanks for feedback!
      10-13-2017, 01:32 PM   #7
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Did you measure the drop?
      10-13-2017, 01:46 PM   #8
twin fed
Doc Brown
twin fed's Avatar
1176
No I never did, but here is a pic with the drop and 10mm spacers
Benzima1324.00
      10-13-2017, 02:19 PM   #9
E92M3GT
Drives: E92 M3
What do you recommend? I as thinking on going 10mm all around (or 12mm)with car lowered on H&R srpings?
I have H&R springs (-0.8" lowering on both front and rear) with 10MM Turner spacers
Perfect looks and no rubbing !
Benzima1324.00
      10-13-2017, 02:30 PM   #10
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Looks good! I will measure mine and share the results.
twin fed1175.50
      10-16-2017, 06:07 PM   #11
DelGriffith
DelGriffith's Avatar
Drives: 2019 SO M2C
I have the H&R's with 10 mm all around. No rubbing on the streets with stock. Went to COTA two weeks ago with 18" square setup. Found the rears rubbing, removed the rear spacers and almost no rubbing after that. I have 1.5 degrees of negative camber front and back. So, beware if you track it!
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
      10-16-2017, 06:36 PM   #12
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Thanks for info! I am getting the car aligned right after the drop. Might not track with 10mm spacers based on feedback. Still haven?t bought spacers yet either.
      10-17-2017, 07:32 AM   #13
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Just measured the gap between fender and tire lip at stock height: 3.5in all around. Will post results once installed tomorrow.
      10-19-2017, 12:02 PM   #14
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Drop was exactly as advertised by H&R: 0.8in all around. They might settle a bit more but I am very happy with the drop and how the car behaves. It will be ready for track next year.
      10-19-2017, 01:33 PM   #15
horsepower_and_hounds
Drives: BMW
I am planning on doing H&R springs also...maybe HAS kit. Not sure yet and see how it looks with the stock wheels. The only worry with the M2 and spacers is the way the fender lip is not rolled all the way up. A friend cut a tire at VIR on a track day but I can't for the life of me remember what his set up was. I know he had 20in ZCP wheels
      10-19-2017, 01:43 PM   #16
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
With the H&R springs, the drop is not that bad.
I am running 19in 437M wheels.
      11-20-2017, 06:00 PM   #17
Drives: BMW
I grabbed andrewc89's H&R springs
Benzima1324.00
AndrewC198910910.50
      11-20-2017, 07:05 PM   #18
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
You will love them.
      11-20-2017, 08:04 PM   #19
///Mē
///Mē's Avatar
281
Drives: 2017 BMW M2 6MT
2017 BMW M2  [0.00]
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold
      11-20-2017, 08:07 PM   #20
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Post installation
Appreciate 4
///Mē281.00
Ilikemike250.50
Seagull287.50
      11-20-2017, 08:08 PM   #21
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Pre installation
      11-20-2017, 09:20 PM   #22
///Mē
///Mē's Avatar
281
2017 BMW M2  [0.00]
Post installation
Looks great!!
Benzima1324.00
m2
