M2 Technical Topics > Suspension | Brakes | Chassis > Alignment Necessary After Lowering?
      10-13-2017, 11:04 AM   #1
MineralGreyMetallic
MineralGreyMetallic's Avatar
639
Drives: 24 BGM M2 6MT
Controversial subject incoming...
I recently installed the M Performance Coilovers. The sales guy at the performance shop suggested I get an alignment after the suspension has "settled" in "about a week."
I know there's a lot of bro science online with car work just like anything else. But it's also been my understanding since I became a car enthusiast in my teens that any ride height change would warrant an alignment.
Then I found this: https://blog.tirerack.com/blog/make-...lower-your-car
  • What do you guys think?
  • Have any of you performed an alignment after lowering your M2 and seen the printout afer that shows things were clearly thrown out of spec by the ride height change?
      10-13-2017, 11:27 AM   #2
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Sales guy is wise - MP coilovers will settle and any change in F &/or R camber will effect toe-in of either axle....
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      10-13-2017, 02:31 PM   #3
lax01
Drives: 2017 M2
I don't know if there is any controversy...I don't know why someone would spend many dollar to modify a suspension and then not confirm that's it properly aligned and working correctly...seems like common sense to me
      10-13-2017, 02:37 PM   #4
MineralGreyMetallic
639
I'm trying to collect data with this thread because there's a severe lack of it on the internet in general regarding this topic.
My time is valuable. I'd rather not spend it doing things I don't have to do. Especially if I can confirm that with hard data.
      10-13-2017, 02:50 PM   #5
MineralGreyMetallic
639
... also I think I might have misinterpreted that Tirerack Blog.
The author states an alignment kit is not necessary, which I'd guess probably means something that lets you adjust beyond the range of the existing hardware for correction. The implication is that a small drop of 1-1.5" can be corrected with the factory hardware. Something more severe might require modifying those parts - what might be more commonly known as a camber kit or something.
I really don't know.
      10-13-2017, 06:17 PM   #6
CommitConfirm
United Kingdom
475
Drives: The Bus
In a word. Yes.
      10-14-2017, 10:54 AM   #7
BAN_M2C
BAN_M2C's Avatar
4180
Drives: 991.2 Porsche GT3, BMW E46 M3
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
This is a no brainer. YES, after changing anything regarding the suspension geometry of the car you should get an alignment to confirm everything is still in spec.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      10-14-2017, 11:28 AM   #8
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
The ?alignment? or crash bolt kit as MB calls it is an eccentric bolt kit or longer bolts used in an eccentric hole you ream out to get extra adjustment to align the car to spec.
What Eibach is saying, is that lowering the car should not put the alignment so far out of spec that you would need an ?alignment? kit to bring it back into spec.
Yes, you need to align the car and probably smart to check it again once the springs settle.
      10-14-2017, 12:46 PM   #9
MineralGreyMetallic
639
Ya, that makes sense. Thanks for helping me understand it better.
      10-14-2017, 12:58 PM   #10
ORIGIN M.
3161
Drives: ///M
Wink Nice going!
Better safe than sorry, is the rule I live by.
      10-14-2017, 12:59 PM   #11
CommitConfirm
United Kingdom
475
Drives: The Bus
BMW state that any fine tread fixing be replaced once removed.
The 12 point 18mm shock strut to guide support (front & rear) nut is single use.
The 5 hex head bolt that hold the guide support to the body are single use. They are stretched when the correct torque of applied and do not provide the correct clamping force if re-used
The 16mm nut for both the front drop link to strut & front strut to hub carrier are also single use.
The bolt that clamps the strut to the front hub carrier is also single use for the same reason above.
The rear shock to lower arm nut and bolt are also single use for the same reasons.
Now, flame suit on, a lot of guys will argue you can reuse them.... but if you go the dealer that will follow BMW guidance and replace these for a reason.
Appreciate 3
ORIGIN M.3160.50
BishUK440.00
CSBM52721.00
      10-14-2017, 11:11 PM   #12
MineralGreyMetallic
639
wrong thread?
Ya, when I ordered the Coilover Kit I also ordered another kit that came with all that hardware.
      10-16-2017, 10:25 AM   #13
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
I am getting new springs installed and I am doing the alignment the same day. Hope it helps your data base.
      11-01-2017, 06:06 PM   #14
MDriven
2017 M2, BSM, 6MT, Exec Package
MDriven's Avatar
Drives: F87 M2, F82 M4CS, E92 M3
I currently have Motion Control Suspension. I heard it is okay to get alignment done once suspension has settled in or after your new suspension has been installed. But alignment is very crucial, do not delay on getting one once suspension has settled.
I got my alignment done right after my MCS coilover's were installed.
      11-01-2017, 09:33 PM   #15
MineralGreyMetallic
639
Just to follow up.
I ended up getting an alignment 2 weeks (not a daily driver) after install. The rears were way off.
Thanks everyone for chiming in.
Bee Pee1779.00
      12-31-2017, 11:34 PM   #16
M3 Alex
M3 Alex's Avatar
Drives: 2018 ZCP M3 - Avus Blue
Just to follow up.
Was it close enough to adjust using the OE hardware, or did you need to get additional adjustable hardware (like camber plates)?
      01-01-2018, 10:17 AM   #17
Bobh59
Bobh59's Avatar
Drives: 2008 335xi coupe
Just to follow up.
Don't forget to align the headlights too.
PPK | Mishimoto FMIC | ER CP | Forge DVs | RB Inlets | RB PCV | BMW PE | Dinan springs/Koni Yellows
      01-01-2018, 03:57 PM   #18
MineralGreyMetallic
639
I did not install camber plates. The adjustments were made with OE hardware. However, the tech did mention that the OE hardware was close to its limits in the rear in terms of adjustment. Not sure if he was exaggerating.
M3 Alex122.50
      01-01-2018, 03:58 PM   #19
MineralGreyMetallic
639
I thought about that. Where would I even go to do that? The dealer?
m2
