10-16-2017, 10:08 AM | #1 |
Rep 12
M240 with dinan sports tuner and VRSF downpipe
Hey guys, just seeing if anyone is running a relative set up as me. I have a m240 with the dinan sports tuner +4, dinan midpipes, Bms intake, and 4.5 in vrsf downpipe. After I installed my downpipe, I?m not getting the same power as I did before. Any reason why? Or do I need to switch to a more aggressive tune like JB4? Just thought I would have got more power, but I guess bigger downpipe, more flow, but less pressure. Any help or thoughts?
10-24-2017, 10:15 AM | #2 |
Rep 146
Drives: Evo9, '22 X3Mc, Turbo S2000
Location: BMW Southpoint, Durham NC. Dinan/Carbahn authorized Dealer.
Because you have significantly changed the airflow characteristics of your engine it is highly recommended you get a proper dyno tune. Once you do you'll see a big bump in power.
10-25-2017, 10:18 AM | #3 |
140
Rep 381
How exactly do you suggest he gets a proper dyno tune on the m240i? The DME is locked.
Current: 2019 640i GT, 2019 MX-5 GT-S, 2015 X1 xDrive35i
Gone, but not forgotten: 2017 m240i, 2016 GTI PP, 2013 Camaro SS, 2009 G8 GXP, 2008 G8 GT, 2007 335i, 2003 530i |
10-26-2017, 10:08 AM | #5 | |
140
Rep 381
Unfortunately, there isn't a shop that has been able to unlock and flash the m240i b58 DME yet, at least that I know of.
10-30-2017, 10:01 PM | #6 |
Rep 1,369
Not sure what the DME being locked has to do with getting dyno tuned. Just because the DME hasn't been cracked, doesn't mean you can't dyno tune the car with a piggyback. It simply means there's no flash tune available yet. Map 6 on the JB4 can be custom tailored and doing so on a dyno to see max gains would be beneficial.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
11-15-2017, 05:35 PM | #7 |
Joint Chiefs of Staff
24182
Rep 190,777
Lot of misinformation here.
OP Only reason i can think of is a boost leak from the downpipe install or a damaged O2 sensor. Since your tune does not datalog, i recommend you get a mechanic to check the downpipe install for any boost leaks
