10-21-2017, 10:22 PM | #1 |
Rep 832
Dinan Stage 1 with MPE or Dinan Free Flow?
Hi all,
I have my 2018 M240i on order and debating what to do about the exhaust. I have the MPE down on the order but am thinking about cancelling it and going with stock for now then upgrading later, likely to the Dinan Free Flow. My question is that I am going to go with the Dinan Stage 1 shortly after break in but am wondering, will I see a difference with it and stock exhaust vs MPE vs Dinan Free Flow? Ideally, I would go with Stage 1 on stock then upgrade to Dinan Free Flow later as long as running the Stage 1 on stock exhaust won't cause any issues vs MPE or Dinan Free Flow out of the gate. On another note, is the Dinan Free Flow any louder than the MPE? I am a professional and want some additional burbles and fun sound, however, when I am pulling away from a client's home, I don't want to sound like a street racer. Thanks |
10-22-2017, 08:34 AM | #2 |
Rep 558
If you want the best of both worlds (quiet when you need it to be and sonorous when you want it to be), my recommendation is to go with the Dinan mid-pipe only, instead of a replacement muffler.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
10-22-2017, 12:18 PM | #3 |
Rep 474
Just curious, if you are just looking for a sound modification, then just the MidPipe, but if you are looking for a power increase (although not that much,. 5-6HP), then, free flow exhaust, correct? How loud is all of it going to be compared to stock?
10-22-2017, 05:58 PM | #4 |
Rep 23
I have the dinan mid pipe and 200 cel sport cat. Insane difference over stock. It's loud, I couldn't imagine getting a MPE as well. Cold start up is very loud, but mitigated by applying the throttle gently. Driving normal in comfort you can be quiet but switch to sport and the burbles are like gun shots. In comfort you can also hear the turbo whistle, which sounds pretty cool.
10-22-2017, 06:03 PM | #5 | |
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
Which sport cat do you have on your M240i?
10-22-2017, 07:11 PM | #7 | |
Rep 832
I want a lower grumble at idle but don't want it to be obnoxious. Had supersprints on my Z4M and it was perfect cut for me. My biggest concern, as mentioned, is weather one exhaust setup vs another is more or less ideal to use with the Dinan Stage 1. |
10-22-2017, 07:36 PM | #8 | |
Rep 558
In Sport it is noticeably louder at higher revs and lots more and louder overrun. No drone. For, me, it is the perfect compromise. The car should have sounded like this from the factory.
10-22-2017, 08:59 PM | #9 | ||
Rep 832
Thanks for the advice! |
10-23-2017, 05:31 PM | #10 | |
Rep 558
It just sounds 'right'.
10-24-2017, 12:04 PM | #12 | ||
Rep 832
07-14-2019, 02:53 PM | #13 |
131
Rep 306
Dinan Stage 1 MPE exhaust - Dinan CAI Runs in the high 11 with good air -consistent low 12 in heat - and is in warranty!!!
mblaucoupe135284.50 |
07-15-2019, 07:05 PM | #14 | ||
221
Rep 314
Status, income, position, has nothing to do with exhaust sound. If you want it loud and to pop and burble, ask. If you want it quiet and to not do those things, ask. Status has nothing to do with sound. Maybe I'm being presumptuous. |
07-16-2019, 11:20 AM | #15 |
Joint Chiefs of Staff
24178
Rep 190,750
REMUS sounds the best but if i had to pick between the 2 options you mentioned i would pick Dinan
