10-22-2017, 02:32 PM | #1 |
Rep 55
JB+ User Feedback?
I have been reviewing the user feedback on the JB4, Dinan Sport, and Dinan Elite tuners on this forum. The feedback seems to fall into three groups: "noticable power increase/smooth power" (good news), "jerky acceleration/jerky shifts" (not so good), and "CELs" (bad news). Based on all users who chose to report feedback to date, the Dinan Elite seems to garner the most good news reports and Dinan Sport the most not so good or bad news.
However, I could not find any specific performance feedback in this forum on the cheapest, easier-to-install tuner (JB+). In contrast, there are a fair number of user reports for the JB+ on the f30 bimmerpost forum (predominantly good news). So what is the feedback on JB+ from the f22 community??? Last edited by havinfun; 10-22-2017 at 02:36 PM.. Reason: wrong spelling |
10-23-2017, 01:35 PM | #3 |
Rep 55
10-23-2017, 02:09 PM | #4 |
Rep 9,709
I'm running the 3 o clock (as shipped) position. I'm up about 30hp at the wheels, 394hp at the crank (from 360).
No CEL's I think the jerky gear change is purely because the power cut (gearbox initiated power cut) is cutting a higher power figure, so is more noticeable. I drive in manual mode, Sport+ by default. |
11-15-2017, 05:36 PM | #6 |
Joint Chiefs of Staff
24180
Rep 190,777
Get it OP, im sure you will like it.
We offer 14 days money back guarantee on this item if you wish to give it a try
11-15-2017, 07:40 PM | #7 |
1165
Rep 1,931
Get it. 200$, adds a noticeable bump it power.
I put mine one 2 years ago on 100% power, stacked on top of my flash tune, and hasn't caused any issues. its also very easy to resell if you move onto something else.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
11-15-2017, 08:10 PM | #8 | |
Rep 55
I LOVE it. I don't plan any other engine mods so a fancier tuner with more sensors was not needed. This one just adds a noticable kick at low RPMs which is mostly in the range that I drive. So far, no hesitation and no CELs. I am quite satisfied. |
AlexM240i101.50 |
11-15-2017, 10:15 PM | #9 | |
24180
Rep 190,777
11-18-2017, 08:36 PM | #10 | |
102
Rep 303
2 questions: 1. How did you remove the TMAP sensor without damaging it ? 2. Do you feel any shifting jerkyness or delay with the JB+ installed ? Thanks. |
11-19-2017, 01:14 PM | #11 | |
Rep 55
Regarding the TMAP sensor: yes, I found removing it a bit tricky. The connector is a very simple design with a white tab on the back that pulls out about 1/8" with a "click". If you look carefully at the JB+ connector before install (which has the same female connector end), you can see that pulling out the tab allows a tiny plastic locking tongue inside the connector to free up and move out of the way releasing the connector from the male part. However, the tongue, although free to move, stays down and locked unless it is pushed gently upward. Since the TMAP female connector points back toward the engine block, there is no room to sneak a small flat head screw driver in there to pry up the tongue (the screw drive handle gets in the way). So I happened to have a screw driver that had its blade bent into a 90 degree angle (sorry, no pictures of this). I pushed this blade into the female connector from the engine side. That pushed the locking tongue up and out of the way, and the connector pulled apart easily. I think a similar "tool" could be made out of a scrap of a tin can or maybe even a paper clip. Hope this helps. |
AlexM240i101.50 |
12-21-2017, 02:16 PM | #12 |
Rep 7
I am selling mine for $100 shipped. I want to buy the dinan sport to be able to change the boost setting remotely.
Hit me up if anyone is interested (rgonza@live.com) |
12-27-2017, 12:48 PM | #13 |
24180
Rep 190,777
Did you get the Dinan module? Our sale ends on Friday
01-15-2018, 10:03 AM | #14 |
102
Rep 303
Engine hesitation and laggy shifting from 3rd gear with my JB+ even using octane booster and premium fuel in my 8Auto M240i. I had to turn the dial to half boost to prevent the laggy shifting. Not happy with it....
01-15-2018, 06:42 PM | #15 |
Tarnished One
76
Rep 362
Sorry it’s not working out man. I’ve been running it now for about 6k miles in mine. Same thing 8zf but don’t experience the laggy shifting. Left mine at the original setting at 3.5 no problems. Run93 octane no booster. Ran it in my 135i for 4 yrs didn’t have any problems then either.
09 LMB M3
Retired: 05 MB 330i, 08 CS 135i, 17 EB M240i, 13 CB 135is, 16 ABM M4 |
AlexM240i101.50 |
