Autotalent
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Sponsors Classifieds > Suspension / Brakes / Chassis / Spacers
      11-01-2017, 01:53 PM   #1
AutoTalent
AutoTalent's Avatar
2306
Drives: e92 M3 6mt | e60 M5 6mt
AutoTalent | SPL Parts | Suspension Upgrade | Lower Control Arm, Toe Links, End Links
Golan@AutoTalent.com
SPL Front Lower Control Arms F8X - Race Version
SPL front lower control arms provide roll center, camber and track width adjustment for the F8X M3 and M4 BMWs and allow for full articulation with the correct ball joint angle. No more jam nuts!! Long gone are the days of fumbling with multiple wrenches to tighten jam nuts in place while trying to keep your bearings orientated correctly. The main arm is slotted to allow the use of pinch bolts and our rotating clamps on our exclusive hybrid adjuster lock down camber and track width settings. Our hybrid double adjuster is machined from 4130 chromoly and is electroless nickel plated for corrosion resistance. Blue anodized titanium hardware shaves even more unsprung weight from the arms without compromising strength. Stainless steel spacers are provided to correct roll center for lowered vehicles. The use of FK rod ends and high misalignment spherical bearings eliminates the flex and binding found in the OEM control arms while allowing smooth articulation. The race version DOES NOT include the headlight adjusting rod.
• Lightweight Aluminum, Titanium, Chromoly and Stainless Steel construction
• Correct ball joint angle for full articulation
• Clamp design allows for easy access to lock down your alignment settings
• Low friction 3 piece Teflon lined FK sphericals and Heim joints/rod ends
• Multiple size stainless steel roll center spacers for precise adjustment
• Made in the USA
SPL TITANIUM Rear Upper Arms BMW F8X M3 M4
SPL adjustable links are an absolute necessity to maintain proper rear camber and reduce tire wear on the street and track. The stock BMW setup has an aggressive camber curve through bump travel, which is very apparent on lowered cars. Excess negative camber causes premature tire wear on the inside edge, and reduced traction on acceleration while too little camber will limit rear grip while cornering. SPL links provide a wide adjustment range for precise rear camber alignment that is easily optimized for street or track driving while eliminating bushing deflection with smooth articulating Teflon lined rod ends in place of the soft factory rubber bushings. Our kit replaces the factory links commonly referred to as the rear wishbone and rear guide links.
Our links feature black anodized and gundrilled 2024 aluminum links, 6061 aluminum clamps, titanium socket head cap screws, tapered stainless steel knuckle mount spacers and FK rod ends. This combination provides superior performance, durability, and ease of adjustment. Long gone are the days of fumbling with wrenches to tighten jam nuts while trying to trying to keep your bearings orientated correctly.
Sold as a set of 4 arms.
• Black Anodized and Gundrilled 2024 Aluminum Links
• 6061 Aluminum Rotating Clamps allow for a wider range of adjustment vs jam nuts
• Titanium Socket Head Cap Screws
• Tapered Stainless Steel Knuckle Mount Spacers
• Low Friction 3 Piece Teflon Lined FK Rod Ends
• Made in the USA
SPL TITANIUM Rear Toe Links BMW F8X M3 M4 + Eccentric Lockout
SPL rear toe arms increase stability and response by eliminating bushing deflection while providing an increased range of rear toe adjustment, necessary for lowered cars or for performance alignments. Even small changes to ride height and camber will effect toe settings and the wide range of adjustment allows you to maximize grip on a track car and extend tire life on a street car. The factory rear toe arms utilize an eccentric bolt and washer for adjustment and lack the precision that SPL Parts rear toe links plus eccentric lockout washers offer. Our eccentric lockout washers ensure that your alignment will never slip like the factory eccentrics are known for under extreme loads. Black anodized and gundrilled 2024 Aluminum main links along with our 360 degree rotating clamp design allow for quick and precise adjustment.
• Gundrilled 2024 Aluminum Links to reduce unsprung weight
• 6061 Aluminum Clamps and Heim Joint Spacers
• Rotating clamp design allows for easy access to lock down your alignment settings
• Low friction 3 piece Teflon lined FK Heim joints/rod ends made in Connecticut
• 6061 Aluminum Eccentric Lockout Washers
• Grade 10.9 Hex Cap Bolts with Lock Nuts
SPL TITANIUM Front Tension Rods BMW E9X/E8X/F8X
SPL TITANIUM series tension rods provide a wide range of front caster adjustment, allowing precise alignment for optimal turn-in response and to compensate for variances between left and right caster. Low-friction, smooth articulating FK spherical bearings eliminate the stock mushy rubber bushing to provide a more responsive steering feel. Anti dive characteristics can also be tuned with the use of our stainless steel spacers
• Gundrilled and anodized 2024 aluminum links to reduce unsprung weight
• 6061 aluminum clamps and Heim joint spacers
• Titanium socket head cap screws
• Stainless steel anti dive spacers
• ASTM A574 socket head cap bolts used for maximum articulation with minimum tensile strength of 170,000 psi
SPL TITANIUM Rear Traction Links BMW F8X M3 M4
SPL TITANIUM Series rear traction links eliminate the soft mushy rubber bushings on the stock links to reduce toe change in the rear suspension under hard acceleration/braking and when going over bumps. This provides more stability and predictability to the rear suspension for tighter handling. Our traction links are also length adjustable to allow the rear suspension bumpsteer characteristics to be adjusted.
SPL Bumpsteer Adjustable Tie Rod Ends E9X/E8X/F8X BMW
Our front tie rod ends allow the tie rod end pivot to be relocated, which will correct bump steer resulting from modified caster or lower arm geometry, thus reducing lap times. On cars that are lowered significantly, relocating the pivot point will also keep the tie rod end from binding, thereby preventing the inner tie rods from breaking or bending when racing.
• Gun-drilled 2024 aluminum turnbuckles to reduce unsprung weight
• High misalignment low friction 3 piece Teflon lined FK Heim joints/rod ends
• 1/2", 1/4" and 1/8" thick stainless steel bump steer spacers for precise adjustment
• Blue anodized titanium jam nuts
SPL FKS Front Caster Rod Bushings E9X/E8X/F8X BMW
Our SPL FKS front caster rod bushings replace the stock flexible rubber bushings with low friction articulating spherical bearings elminating bushing deflection and reducing friction. This maintains optimum suspension geometry under load to improve braking and handling feedback. Massive 1" sized FK racing bearings with self lubricating Teflon liners are used to ensure maximum performance and durability. Innovative CNC'd offset bearing spacers provide +/- 4 degrees of caster adjustment.
• 6061 Aluminum bearing housing with outer knurl
• 6061 Aluminum offset spacers provide +/-4 degrees of caster adjustment
• FK one inch spherical bearings
SPL PRO Rear Endlinks F8X BMW
Our SPL PRO rear endlinks for the BMW F8X chassis feature massive Teflon lined FK 1/2" bearings to provide the highest load capacity for use with stiffer aftermarket sway bars. Custom heat treated chromoly high misalignment studs connect to the sway bar and offer extreme articulation capability (65deg) to prevent the endlink from binding when used with different adjustment holes on aftermarket sway bars.
Our endlinks are length adjustable to eliminate preload on the sway bars, which can result from uneven settling of springs or uneven suspension heights from corner weighting. Black anodized 6061 aluminum turnbuckles work in conjunction with the left and right hand threaded rod ends for simple and precise adjustment. These end links are perfect for street or race applications.
How to Place Your Order:
Phone Domestic: (310) 231-0292
Phone International: (310) 231-0292
E-mail:
Website:
www.AutoTalent.com
Payment:
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
      07-05-2021, 05:33 PM   #2
AutoTalent
AutoTalent's Avatar
2306
Visit our website by clicking HERE. Please feel free to reach out with any questions or inquiries!
      08-10-2021, 07:53 PM   #3
AutoTalent
AutoTalent's Avatar
2306
      09-03-2021, 07:28 PM   #4
AutoTalent
AutoTalent's Avatar
2306
      09-21-2021, 07:48 PM   #5
AutoTalent
AutoTalent's Avatar
2306
      10-18-2021, 05:40 PM   #6
AutoTalent
AutoTalent's Avatar
2306
      11-04-2021, 01:47 PM   #7
AutoTalent
AutoTalent's Avatar
2306
      11-11-2021, 12:15 PM   #8
AutoTalent
AutoTalent's Avatar
2306
      11-22-2021, 11:33 AM   #9
AutoTalent
AutoTalent's Avatar
2306
      03-25-2022, 07:26 PM   #10
AutoTalent
AutoTalent's Avatar
2306
      05-04-2022, 10:50 AM   #11
AutoTalent
AutoTalent's Avatar
2306
      05-12-2022, 11:04 AM   #12
AutoTalent
AutoTalent's Avatar
2306
      05-23-2022, 10:57 AM   #13
AutoTalent
AutoTalent's Avatar
2306
Tags
auto talent, lower control arms, spl parts, tie rods, toe links
f80post
