Surging Noise After Forge DV Install
11-01-2017, 11:58 PM | #1 |
Rep 108
What's up guys.
Currently on the car are oem location vrsf inlets and BMS dci. Recently installed Cobb charge pipe and forge dv. At low throttle there's a loud surging noise for a couple seconds and then it goes away. Can't figure out what's causing it. I have a sound clip. If anyone wants me to send to them. Any info is much appreciated! |
11-02-2017, 12:34 PM | #2 |
1933
Rep 1,532
Make sure to use a dedicated line to the forge, they don't mandate it in their literature (best I know) but they benefit from an upgraded line.
Also make sure you use the correct spring. Forge tends to recommend springs based on boost pressure, not vacuum, which IMO is the wrong way to do it. When in doubt use a softer spring. If it doesn't hold boost something else is wrong. Chris |
11-02-2017, 12:37 PM | #3 | |
Rep 108
11-02-2017, 12:38 PM | #4 |
1933
Rep 1,532
Yep, drilling a hole in the mani and putting a nicer/bigger line to the BPV's. You have two of the BPV's, so it's even more important. It's not a big deal if you take your time and work slowly.
Chris |
11-02-2017, 12:43 PM | #5 |
Rep 108
Will that fix the surging noise that's happening down low? Don't have this car for to much longer and would like to avoid permanent mods if possible.
11-02-2017, 12:54 PM | #6 | |
1933
Rep 1,532
Try a softer spring in the forge first... see if that helps you out. It's not ideal but might get you close enough. Chris |
feuer4275.50 |
11-02-2017, 04:54 PM | #7 |
Rep 2,841
Lol.....before doing anything else, check if there are YELLOW springs in the package. If so - swap to the yellow ones.
The green ones don't hold enough boost and are too soft, so they are probably venting too soon, which is probably making the noise you are hearing. |
ArweenX119.00 |
11-02-2017, 05:17 PM | #8 | |
Rep 108
https://www.forgemotorsport.com/Upra...duct--825.html |
11-02-2017, 05:28 PM | #9 | ||
VAG Survivor
40
Rep 150
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
11-02-2017, 05:43 PM | #10 | |||
Rep 108
11-02-2017, 06:40 PM | #11 | |
Rep 2,841
ArweenX119.00 |
11-10-2017, 04:19 AM | #12 | |
596
Rep 1,693
"Note: The quoted spring pressure (PSI) relates to the un-assisted clamping force of the spring and should NOT be taken as an equivalent to boost pressure when determining suitability. Once a valve is fitted to a car it is subjected to various pressures that act upon the diaphragm or piston to aid its respective ability to seal or hold boost. An example of this, would be when using a FMCL007P valve on a 1.8T engine as found in the TT 225hp. The boost pressure on a "chipped" car can peak at 26psi. The recommended spring would be the Green or Yellow." A spring can't be rated to a positive boost pressure, only a vacuum pressure before venting. I'd personally use the green spring. The stock DVs start to open at only -3.5psi vacuum. |
11-11-2017, 10:58 AM | #13 | |
1933
Rep 1,532
They all work about the same way. We subscribe to the way Tial recommends it be set up, which is more based on vacuum than boost. Chris |
bradsm87595.50 |
11-14-2017, 06:28 AM | #14 |
VAG Survivor
40
Rep 150
so basically if the car sees around 10psi of vaccum we should set the spring accordingly
