11-17-2017, 11:41 AM | #1 |
310
Rep 339
Bilstein B16 vs Ohlins R&T? Feedback?
I was leaning towards Ohlins R&T coilovers but wanted to see if anyone here has any feedback or even a set installed on Bilstein B16 coilovers. Couldn't really find much info on them here.
instagram: @ sf87_m2
11-17-2017, 11:48 AM | #2 |
Rep 4,541
Drives: 2015 328d xDrive
i know @chris.praeger has the b16 installed
http://f87.bimmerpost.com/forums/sho....php?t=1420969 also i've seen a few posts of people complaining about the R&T http://f87.bimmerpost.com/forums/sho....php?t=1425894 |
just blaze310.00 NYC Bimmer259.50 |
11-18-2017, 07:16 AM | #3 | |
310
Rep 339
11-18-2017, 04:32 PM | #4 |
Rep 199
I had the Ohlins R&T installed 3 weeks back and love them so far...I had the spring rates lowered 15% to 80N/mm front and 160N/mm rear (vs 90 and 190 respectively) as I am mainly a street and back road guy.
So far no noise, as quiet as stock and amazing....easy to adjust from 5 clicks (track) 10 clicks (back road/canyon) and 15 clicks (street)...takes 2 minutes. So I would give them a 5 star rating so far!!!!
2017 BMW M2 BSM 6spd with Fabspeed/HJS 300 cell Sportcat, BM3 OTS Stg 2 tune, Dinan Turbo, MST V2 Inlet, Dinan IC, Dinan CAI, Ohlins, Carbon Fiber+Aluminum Strut braces.
2007 BMW 335i (sold); 1997 BMW E36 M3 (sold); 1988 BMW 535is (sold); 1984 BMW 323i Alpina (can't believe I sold),1969 BMW 2002 Ti (spec'd as Ti; and yes I sold this too...). |
just blaze310.00 Spartan King79.50 |
11-20-2017, 10:24 AM | #5 |
Rep 582
I've had the Bilstein B16 PSS10 coilovers installed on my 2017 M2 for about 5,000 miles now. I drive the car on street and track (about ten days this year) and my suspension setup includes the Bilsteins, GC camber plates (running at 2.7 deg) and SC2 tires.
Overall - A good, quality option at a price point materially lower than the Ohlins R&T. Ride - A little stiffer than the stock setup over uneven pavement but I've been living with it without too much complaining from the girlfriend - and I live in Manhattan. Generally, l keep them at the softest settings for the street and crank them up a bit for track days. Over wavy pavement, there is much better control than the stock setup - with the stock suspension the tires tended to bounce out of control in some situations. The Bilsteins remind of the very controlled ride in some of the Porsches I have driven. Quietness - So far both the B16s and camber plates have not made a sound. Thankfully, the "swoosh" sound from the stock shocks when going over speed bumps is also gone. Adjustability - Single adjustment knob for compression/rebound ratio makes life easier for someone like me who is new to coilover setup. They are located at the bottom of the shocks so a jack is necessary to reach them, but otherwise easy to adjust. Nice solid and clear clicks for each setting. |
just blaze310.00 M2RAW121.00 |
11-20-2017, 12:14 PM | #6 | |
310
Rep 339
11-21-2017, 10:05 PM | #7 | |
BimmerPost Supporting Vendor
3815
Rep 54,314
Drives: F80 M3
03-15-2018, 04:00 AM | #8 | |
89
Rep 314
You still happy with the suspension? are you lowered much? is the car more comfortable than standard ? |
03-18-2018, 12:33 PM | #9 |
Rep 415
I have B16’s/pss10’s on the way for mine. Ran V3’s on my last car so it will be nice to compare the 2 brands. Adjustment will definitely be easier on the bilsteins. Most likely pair them up with Millway camber plates at some point too.
03-18-2018, 02:15 PM | #10 | |
Rep 199
The longer answer is that I love the Ohlins and believe they are a superior suspension for the M2...but....even with my softer springs (than the standard Ohlins M2 offering ) of 80N/mm front and 160N/mm rear and at 20 clicks (the softest setting) my suspension is slightly stiffer than stock. Actually I think it is about the same as stock when new, but when I compared my new set up with a friends M2 with 8,500 miles on it, his seemed a little more compliant and softer riding than mine. That said, mine are of course new and my car still only has 3,000 on it. The reason I am still loving the Ohlins is they have such a fricking 'stuck to the road' feeling...no more bounce, they just seem to absorb road bumps, particularly the medium and larger road irregularities which can really upset the chassis in a turn. So I love my Ohlins but if you want a system that is softer I would go with the Dinan or I would order the Ohlins with 70N/mm front and 140-150N/mm rear which Jake at Ohlins said the valving can handle....he said you can go up to a 25% lower spring rate (from standard) before you start to defeat the valving. Either way, this car rocks....hitting the track for the first time in 2 weeks...hmmm, back to 5 clicks settings is my plan for track duty....
03-19-2018, 09:10 PM | #12 | |
Rep 190
:::: 2017 AW M2 :::: (SOLD)
gsrbri559.50 |
03-19-2018, 10:08 PM | #13 | |
Rep 199
Bazgab132.00 |
03-19-2018, 10:15 PM | #14 |
Rep 199
It takes 5 minutes; I put a towel on the garage floor (or if I am out driving I bring a towel) and lay on my back, takes 20 seconds to locate the lil knobs and click away...fronts click easily, the backs take a little more finger strength...but it takes all of 5 minutes and you can go from 3-5 clicks which is exceptionally stiff (and therefore even flatter in turns and quicker responsiveness)....to 20 clicks, ready for the road....If I was going out for a morning of backroads I would swap it to 12 clicks, which is a nice compromise.
gsrbri559.50 |
03-20-2018, 03:51 AM | #16 | |
89
Rep 314
hmmm that's very interesting about the stiffness compared to stock. Do you think that the 70/150 combo would make it perfect? Why haven't you changed the spring yourself to 70/150 ? how much lower than standard is your car? So your saying it rides as good as standard roughly lowered? She is a bit of Kanga to buy this kit so yeah just wanting to make sure i'll be happy with it. Think i'm a 70/150 guy though. Last edited by JL1; 03-20-2018 at 03:58 AM.. |
03-20-2018, 10:22 PM | #17 | |
Rep 199
On ride height, ..it put me approx 1 cm lower than stock. So what exactly does..." She is a bit of Kanga really mean????"?????
03-21-2018, 03:14 AM | #18 | ||
89
Rep 314
Haha, it means she is a bit of cash, 'Kanga' to an Aussie means cash or money. |
03-22-2018, 04:45 AM | #19 | |
89
Rep 314
Sorry not sure if i asked previously or not? What brand springs are you using ? |
03-22-2018, 11:21 PM | #20 | |
Rep 199
48010-19 200mm 65mm 70 N/mm // 400 lbs/in // 7.1 kg/mm 48010-23 200mm 65mm 80 N/mm // 458 lbs/in // 8.2 kg/mm 48010-27 200mm 65mm 90 N/mm // 515 lbs/in // 9.2 kg/mm 48010-31 200mm 65mm 100 N/mm // 572 lbs/in // 10.2 kg/mm 48010-35 200mm 65mm 110 N/mm // 630 lbs/in // 11.2 kg/mm 48010-39 200mm 65mm 120 N/mm // 687 lbs/in // 12.2 kg/mm 48010-43 200mm 65mm 130 N/mm // 744 lbs/in // 13.3 kg/mm 48010-47 200mm 65mm 140 N/mm // 801 lbs/in // 14.3 kg/mm 48010-55 200mm 65mm 160 N/mm // 915 lbs/in // 16.3 kg/mm 48010-63 200mm 65mm 180 N/mm // 1030 lbs/in // 18.4 kg/mm 48010-71 200mm 65mm 200 N/mm // 1144 lbs/in // 20.4 kg/mm
03-23-2018, 04:13 AM | #21 | |
89
Rep 314
