Considering buying a 335d
11-19-2017, 07:52 PM | #1 |
Rep 1,473
I have owned many BMW's E46M3, 135i, Z435i and I basically tuned them all with FBO. My current dd is a 2006 Jetta TDI and it is a great car but I think that I am ready to switch back to BMW and buy a 335d. They are becoming very reasonably priced and it seems like a good time to make the switch.
In my state, NC, we don't test emissions on diesel automobiles so I will certainly replace the downpipe and tune the car. What should I look out for in my search? Are their common failure items that I would want to consider when shopping. Thanks |
11-19-2017, 09:08 PM | #3 | |
Rep 202
Other items that commonly fail on the m57 are the boost pipe on the inlet side of the intercooler. Sub-$200 DIY. You know yours has failed if the front-lower-left side of your engine bay looks like the inside of a chimney. The crank case breather hose also likes to disintegrate and make a mess of things on the top side. A fairly cheap fix. Vacuum hoses tend break from time to time. Not an expensive fix, but can be a pain to diagnose/locate leak/access part. I've also noticed a lot of folks have issues with the glow plug controller. I haven't had an issue with it and am not really well versed in the causes/symptoms to say much about it, but it's definitely something worth searching for on the forum. Apparently it can be replaced without removing the intake -- so that's good news. Injector failure can happen as well. I need to do more reading on the causes and symptoms myself, but I bring it up because replacement is expensive. Regular replacement of the fuel filter would be a logical first line of defense here. The other issue with this car is the EGR and exhaust aftertreatment system. Check out the alphabet soup sticky regarding your options. I would say this is the biggest issue with the car and the one you should familiarize yourself with the most before buying one. You seem like you've already done a fair amount of reading about the issue, but fully exploring the rabbit hole is well worth the time. As with any used car buy, a well-documented service history is extremely valuable. Pass on anything with service history that is unknown or shows neglect. |
12-31-2017, 02:30 PM | #4 |
Rep 1,473
I am curious about the reliability of the turbos and the M57 longblock. I realize that most of the issues with the 335d are emission, boost pipe or balancer related. I live in a state (NC) that doesn't test emissions on diesel cars so I plan to just remove anything emission related. How have the OEM turbos held up and are there any know failures of the short block or long block?
12-31-2017, 08:44 PM | #5 |
Rep 238
Sans emissions taking care of the maintenance items they are usually rock solid. Transmission fluid IS NOT Lifetime. Change the thermostat if the temp does not go above 175f.
