12-22-2017, 11:16 PM | #1 |
Rep 13
Winter Tire Size Help
Hey Guys, need a little help on some winter tires.
I have my stock 19inch 331 rims that I'm going to be using so I need some suggestions on which is a decent snow tire as well as size I should run. 535i RWD. Last edited by R1ckyB0bby; 12-23-2017 at 12:55 AM.. |
12-23-2017, 10:03 AM | #2 |
Rep 5,140
Staggered wheels?
I still recommend square tires for winter use. 245/40-19 would be OEM size. 245/45-19 will work aswell. Slightly higher sidewalls helps with better traction in snow, comfort and wheel protection. |
12-23-2017, 01:44 PM | #3 |
1569
Rep 29,202
Yes, just go with the OEM size, 245/40/19. Even if the rear wheels are staggered (9" wide and 8.5" in the front) 245/40/19 works great. Got that myself.
12-23-2017, 05:12 PM | #4 |
Rep 13
Yes they are staggered, so 245/40/19 all the way around? Do you have any recommendations on a decent tire thats reasonably priced. We have only had a little snow so i just need them to last a few months then i can put my niches back on.
12-25-2017, 10:26 PM | #5 |
Rep 2,196
I am running Bridgestone Blizzaks and think they are a pretty good winter tire. I had Dunlop Wintersport 3D in the past and prefer the Bridgestone. They are really good in a few inches of powder and slushy conditions.
Bake
2011 Alpine White on Black 535i M-Sport 2013 Space Gray on Fox Red M3 Vert |
02-08-2018, 09:41 PM | #6 |
Rep 455
When I lived in University Heights, NE Ohio, I ran Michelin X-Ice. My work was in Geauga County, and the winter roads were brutal, at times. I've tried other brands; however, Michelin is my choice for a dedicated winter set.
I found the X-Ice to handle better than the Blizzaks on ice. On the other hand, the Blizzaks had a slight edge when plowing through snow. Both, are very good snows, and you can't go wrong with either. Last edited by John H.; 02-08-2018 at 10:01 PM.. Reason: Spelling correction. |
