TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > m3 steering rack and caster
      01-13-2018, 03:24 PM   #1
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
Anybody run one of these on an e9x non-M and have camber plates with caster adjusted to full positive? And without hooking up the Servotronic?
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
      01-13-2018, 07:40 PM   #2
Cloud9blue
Cloud9blue's Avatar
Drives: around the potholes
do it and let me know :P
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization
      01-13-2018, 09:09 PM   #3
justpete
2019 BMW M6  [10.00]
I think the answer's in this thread
http://www.1addicts.com/forums/showt...1137304&page=3
Tried to delete this topic but couldn't after I read through it.
      01-13-2018, 10:29 PM   #4
Cloud9blue
Cloud9blue's Avatar
Yea, I read that thread a while ago. Seems like a lot of tinkering with the coding and electrical to get the servo to work properly. Just not sure if it is worth the trouble for a dual use car like mine.
Personally I think the steering ratio is fine unless you autocross a lot. Getting rid of the stock bushings improve the feel more than changing the steering ratio on these cars IMO.
      01-13-2018, 11:17 PM   #5
justpete
2019 BMW M6  [10.00]
Bottom line for me is that without a steering angle sensor servotronic is irrelevant so that removes one buncha crap to deal with.
Caster was 8.3deg at one point and then back to 7deg at another and it didn't seem to matter terribly at low speed once the driver was used to it which is what I was concerned about since the Vorshlags are now set all the way to the rear.
The slow steering drives me nutz so I'm looking forward to the M3 rack to make rotation a bit easier to effect.
      01-14-2018, 10:07 AM   #6
feuer
feuer's Avatar
Drives: wife crazy!
If I'm understanding correctly you are driving with steering angle sensor disabled ?
      01-14-2018, 11:11 AM   #7
justpete
2019 BMW M6  [10.00]
Yes. Best mod, evah!
      01-14-2018, 11:39 AM   #8
feuer
feuer's Avatar
Drives: wife crazy!
How is the ABS module liking that?
      01-14-2018, 11:43 AM   #9
justpete
2019 BMW M6  [10.00]
ABS and stability are totally non-functional, thankfully. This is one of the things I was trying to find a way to do to begin with, didn't realize it was so easy to do. Of course it kills hill assist which makes things exciting with that clutch and self-canceling turn signals don't work anymore so I have to remember to do it manually since you can't hear them at all but hardly a concern in return for the benefits.
      01-15-2018, 02:27 PM   #10
bbnks2
Drives: 135i N55
Servo assist is a creature comfort for an expensive car... The steering isn't that heavy to warrant going through all the effort...
You seem to be worried about steering effort AT SPEED? You really only need to be concerned about being at a DEAD standstill. The slightest roll and the wheel is easy enough to turn. Concerns about steering weight are grossly overstated unless you've got the bones and muscle structure of an 85 year old and you NEVER leave parkinglots/driveways.
      01-15-2018, 03:32 PM   #11
justpete
2019 BMW M6  [10.00]
Never said anything about effort at speed, no idea where you get that. It's a track car with a cage I can drive on the street so it's pretty obvious steering effort isn't a concern. Front brake cooling limits steering lock to begin with and there's no parallel parking around here so who cares. Querying only those doing this _and_ with max positive caster.
I'm assuming the wheel will be easy to turn since there is hydraulic assist, even at a standstill and with maximum positive caster. Assumed the Servotronic wasn't necessary in that it's for ease of low speed turning although I've never understood the necessity of that.
      01-15-2018, 10:37 PM   #12
feuer
feuer's Avatar
Drives: wife crazy!
bbnks2 and justpete have your driven your cars without hydraulic power assist?
      01-15-2018, 10:44 PM   #13
justpete
2019 BMW M6  [10.00]
No, hadn't intended to but it's a possibility.
      01-15-2018, 11:16 PM   #14
feuer
feuer's Avatar
Drives: wife crazy!
Well I have not driven driven either, just moved few around the shop that had broken servo pumps. I must say that you quickly learn to appreciate the assist. I don't think neither of us would like the steering with out assist on these cars as daily drivers. Or even track only because front end is heavy and we usually all run oversized tires.
      01-15-2018, 11:19 PM   #15
justpete
2019 BMW M6  [10.00]
Agreed which is why I never intended to ditch the hydraulic assist. The Servotronic assist will be eliminated simply by leaving it disconnected which is fine by me.
feuer4275.50
      01-16-2018, 12:36 PM   #16
bbnks2
Drives: 135i N55
Yes, it's a night and day difference... without hydraulic assist you can't realistically drive the car lol
Servo assist, if made to work, would compliment the hydraulic power steering at low speeds. It is not a substitute... Like I said, servo assist is just a creature comfort to keep the executives and CEO's that own M cars happy. The Servo "boost" kicks in to reduce steering effort at low speeds. You can delete servo assist on M3's... people have been doing it for years because they don't like the feel of the boost at low speeds.
      01-16-2018, 12:44 PM   #17
justpete
2019 BMW M6  [10.00]
Servo assist, if made to work, would compliment the hydraulic assist at low speeds. It is not a substitute...Like I said, servo assist is just a creature comfort to keep the executives and CEO's that own M cars happy. The Servo "boost" kicks in to reduce steering effort at low speeds. You can delete servo assist on M3's... people have been doing it for years because they don't like the feel of the added steering boost at low speeds.
Can't imagine anyone wanting to, weird idea there...lol
Servotronic must be for moms at the mall or something, baffled as to the point of it.
Oh, and it looks like cost is about $2620 with a few hours of dealership labor at my discounted rate. Not bad.
      01-16-2018, 12:54 PM   #18
bbnks2
Drives: 135i N55
I love the feel. Go for it. I wish I had done it sooner, but I only really replaced mine because it was leaking and I finally had enough of topping off the fluid lol... Power steering fluid is expensive.
Also, I saw you linked to an install thread. Just a note, I HAD TO break off the plastic tab on the rack. If I didn't, the rack would only have bolted up in a "clocked" orientation. I broke the tab off and mounted the rack at dead center of its range of movement. The steering wheel takes exactly 2.25 turns in either direction to full lock. Maybe 1-series needs to break the tab off to properly clock the rack and 3-series doesn't? I don't know for sure, but make sure you install the rack dead center or you'll hit full-lock quicker in 1 direction than the other lol....
Also, take this as an opportunity to installed some MYLE upgraded tie-rod ends. They are cheap enough and this is the ideal time to do it.
feuer4275.50
      01-16-2018, 01:01 PM   #19
justpete
2019 BMW M6  [10.00]
The dealership race team car chief does all the work on my car. They've been building BMW race cars for many many years and they do a shitload of custom work, etc. so they'll get it done correctly no matter what they have to do. Classic BMW in Plano, TX Classic BMW Racing
Not impressed with Myle, will use new stock parts.
bbnks21206.50
      01-16-2018, 01:17 PM   #20
feuer
feuer's Avatar
Drives: wife crazy!
To my knowledge they all do in order to be centered. Also I believe early models m3 was available with out the servo assist at low speeds.
      01-16-2018, 01:19 PM   #21
feuer
feuer's Avatar
Drives: wife crazy!
wow that is expensive. Would not you consider DIY or competent independent mechanic shop?
      01-16-2018, 01:23 PM   #22
justpete
2019 BMW M6  [10.00]
It's negligible to me, I'm paid more than twice the equivalent hourly rate so I'd have to be nuts to do it myself w/o a lift. And I only use new parts from the dealership for any project. Wouldn't use anyone else, no one's as good as these guys, period.
feuer4275.50
